Turn Signals and Brake Lights - Not working
  • Stevo-iX
    • Jul 2010
    • 231
    As the title says, both are not working.
    But my hazards are working perfectly fine.
    It started last night, but was fine again when I got in my car this morning....
    And then after about 15 minutes of driving... not working again.
    I haven't driven it again yet, but I'm looking through the etm, and I'm going to checkout the ground for the lights in the trunk when I get back to my car tonight.
    What else should I do?
    Thanks guys
  • CabrioPunk
    • 1451
    Lampenkontrollergeraet.
    It is a relay located in the trunk, driver's side. Give that a try.
    • Stevo-iX
      • Jul 2010
      • 231
      Hmm alright, I'll give that a look. Anything else?
      • AndrewBird
        The Mad Scientist
        • 11898
        Could also be the flasher.
        • Stevo-iX
          • Jul 2010
          • 231
          Looked at the light check relay, seemed one of the connecters was loose by a tiny bit. Now they work...hopefully permanently.
          • CabrioPunk
            • 1451
            I guessed right?
            • Stevo-iX
              • Jul 2010
              • 231
              Ehh, ok now the problem is more persistent. I had them working for a few days and now it's not working again most of the time...it'll randomly work sometimes when i first start up my car and then quit 1 minute or 2 into my drive.
              And one more symptom I've now noticed when the turn signals and brake lights don't work, the map lights don't work then either. But work as soon as the other two work again.
              Any help is much appreciated. Thanks!
              • mr.vang
                • 4371
                e30 have so much electrical problem. my gauge and mp3 deck work off and on. i hate it.
                • Stevo-iX
                  • Jul 2010
                  • 231
                  yeah, it kinda comes with the whole old german car thing haha. my wipers don't work right now either, but that's been like that since I got the thing in july so unrelated to this. I think.
                  • DrMcDave
                    • 1793
                    You might have a bad flasher button. Replace that. I know that the turn signals won't work if the button isn't installed so perhaps your problem stems from there.
                    • DaveSmed
                      • Apr 2007
                      • 1406
                      When its not working, try to beep the horn.
                      -Dave
                      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                      Need some help figuring out the ETM?
                      • Stevo-iX
                        • Jul 2010
                        • 231
                        horn didn't beep, but it hasn't since I got the car.
                        • DaveSmed
                          • Apr 2007
                          • 1406
                          In that case, i'm gonna go out on a limb and say it's something along the "R" terminal of the ignition switch (how are your gauges/stereo and check control?) or if that stuff is OK, you have a problem with pin 8 of C114. The shitty part is C114 is on the bottom of your fusebox and sucks to get at.
                          Instead, check it by popping out K2. Take a look at the bottom of it and look for the terminal labeled 86. Matching it up with the terminals in the fusebox, check K2 terminal 86 for battery voltage with the key (and all of the offending components) switched on.
                          -Dave
