Radio Wiring and Amp Bypass
This is a sticky topic.
  • danielmb
    • Mar 2014
    • 1
    #406
    Alpine Head Unit
    After reading this thread, I am going to attempt to install an Alpine CDE-HD149BT, albeit with great trepidation. My car has no fader and tweeters on the doors by the mirrors. I assume this means I have the premium stereo. Assuming I have the premium stereo, is it necessary for me to bypass the stock amp or will it function with the new head unit?
    Daniel Briggs
    1989 325iC
    • StereoInstaller1
      GAS
      • 22679
      #407
      You can use the stock amp if you are OK less sound quality.
      Your deck (hell, any $89 WalMart deck) makes better quality power and more of it.
      You did not say what year and model your car is, but if it is no fader and has tweeters, the car should be '91, correct?
      Don't be skeered, by now hundreds of installs have happened directly because of this thread. R3V will take care of you, and if they don't, I will.
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • tomwas
        • Dec 2010
        • 387
        #408
        First, let me say this is NOT applicable to all E30s. Generally, Late Model (88+) will have this wiring on premium sound cars. IF you have a fader in the dash, this MAY work: you need to unwrap about 8" of fader harness to see if you have 4 pairs of speaker wires, as some cars have only 6 wires, not 4 pairs (8 total) so if this chart does not apply PERFECTLY to your car, don't use it.
        Quick disclaimer: this is not idiot proof. You mess it up, don't whine at me, I do not care.
        If this saves you countless hours of hassle or you are just feeling generous, feel free to paypal me a tip. Add "@gmail.com" to Stereoinstaller1 and I promise to only use the money for projects on my car.
        I have a 90 vert w/prm sound, no fader and i'm not able to locate the brown/orange all grounding - wire in the trunk......... what am I missing..
        OK, here is the info.
        Obviously, what you do here is simple: connect the "deck" wire to the "dash" wire, then back at the trunk, connect that "dash" wire to the "speaker" wire.
        This is not rocket surgery, boys. Get it done.
        Aftermarket-----------Dash Wires-----------Speaker Wires
        RF+ Grey--------------Blue/Red-------------Grey/White
        RF- Grey/Black--------Brown/Orange--------Grey/Brown
        LF+ White------------Yellow/Red------------Grey/Red
        LF- White/Black-------Brown/Orange--------Grey/Violet
        RR+ Violet------------Blue/Black------------Black/White
        RR- Violet/Black-------Brown/Orange--------Black/Brown
        LR+ Green------------Yellow/Black----------Black/Red
        LR- Green/Black-------Brown/Orange--------Black/Violet
        (+12V Unswitched) Yellow----Red/Green (Changes to Yellow at C302)
        (+12V ACC) Red-------------Violet/White (Changes to Voilet/Grey at C302)
        (Ground) Black---------------Brown (may also be Brown/Black)
        (ILL) Orange-----------------Grey/Red (Changes to White at C302)
        (P ANT) Blue-----------------White (this is one of 2 white wires)
        (AMP REM) Blue/White--------White (this is the one in the same harness as the speakers)
        Luke
        sorry my posting ended up in the middle of the quote, i have a 90 vert w/prem sound, no fader.. not able to locate the brown/orange - wire that all speakers ground to in the trunk amp harness, what am i missing....
        Now on my 26th BMW...
        • StereoInstaller1
          GAS
          • 22679
          #409
          Tomwas, please post year and model, psychic skills are being limited by evil conspiracy, sorry.
          Closing SOON!
          • tomwas
            • Dec 2010
            • 387
            #410
            Yes, it's a 90 325i vert with premium sound and no fader in the dash, has an aftermarket HU, have managed to get all front spekers working fine, (door tweeters and kick panel speakers), rears have minimal poor sound coming out of them..... and my central locking stopped working??? My car VV
            • tomwas
              • Dec 2010
              • 387
              #411
              Found i had a blown fuse to my door locking, my pwr antenna would not work also, found a fuse was missing in the fuse block, put one in and now works correctly...... Still no rear speakers are operating and fronts are lacking good bass sound.... wtf.....
              • StereoInstaller1
                GAS
                • 22679
                #412
                did you get it straightened out, Tom?
                Closing SOON!
                • tomwas
                  • Dec 2010
                  • 387
                  #413
                  No,still no rears, have to get back in the trunk in depth.. Thinking I'll hook up the front grounds to the rear grounds'.....
                  • StereoInstaller1
                    GAS
                    • 22679
                    #414
                    No, you can't. No combining positives or negatives, it will overheat if not smoke your deck.
                    You have correct color codes all the way through? Did you test the speakers themselves? Have you pulled the rear seat and inspected the wiring? Let me know if I can help.
                    Luke
                    Closing SOON!
                    • E30 Wagen
                      • Jul 2005
                      • 3431
                      #415
                      Anybody have a write-up on the wiring for a non-premium stereo? I've got a '86 325e with the original stereo wiring all intact and the wire colors in the OP write-up don't match. Mainly having trouble with the power connections.
                      My Feedback
                      • StereoInstaller1
                        GAS
                        • 22679
                        #416
                        Did you get it figured out yet?
                        Closing SOON!
                        • Pantless Spency
                          It's McRib time!!!
                          • Feb 2011
                          • 7283
                          #417
                          Trying to do this myself...
                          I have an 86 325e.
                          No amp from what I know, fader is 6 wires total, and there are a total of 9 wires leading to the deck not including the antenna wire.
                          Any idea where I should start?
                          Fader:
                          These are labeled L and R not sure if there front or rear though:
                          This plug is labeled +12v
                          And these are not labeled:
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7283
                            #418
                            And the harness for the head unit.
                            8 speaker wires total (4 speakers pos/neg for each)
                            And 4 other wires that include remote.
                            Yellow is constant 12v
                            Red is ignition 12v
                            Black is chassis ground.
                            Blue is remote.
                            • Pantless Spency
                              It's McRib time!!!
                              • Feb 2011
                              • 7283
                              #419
                              I have an 86 325e.
                              Fader:
                              so i figured out a few new things.
                              brown wire is labeled grd for ground, the one next to it (violet/grey) is labeled ign for ignition 12v.
                              the green red violet red pair is labeled battery on the stock head unit, so i would assume green/red wire is constant 12v, but i have no idea what the other one is.
                              the white wire with two spade connectors is labeled pwr ant for the power antenna.
                              and i now know that 4 of the fader wires are each positive wires to speakers, and the L R pairs of wires on the head unit are negative wires for the speakers.
                              i just cant figure out which negatives go where.
                              • Thizzelle
                                • 4422
                                #420
                                grey red is illumination but your plug to head unit doesn't have a wire for it.
                                "I wanna see da boat movie"
                                "I got a tree on my house"
