Radio Wiring and Amp Bypass
This is a sticky topic.
  • petercory
    • Jan 2021
    • 16
    #571
    Have a '90 Conv W/Premium Sound & no Fader. I've done the Amp Delete Bypass. The Kick Panel & Rear Speakers work ok, but the Tweeters just have a low pitched noise when the other speakers sound normal. Do the Tweeters have to be re-wired?
    • bradnic
      • Jul 2012
      • 3551
      #572
      Did you change the front kick panel speakers? They have a crossover on them for the tweeters
      HOWTOs:
      DB vert plastic bumpers
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • petercory
        • Jan 2021
        • 16
        #573
        No, I haven't changed any of the Speakers. Do I have to change the kick Panel speakers or will a wiring change solve the problem?
        • SPOautos
          • May 2024
          • 6
          #574
          Hello! Newbie here....I'm planning before taking apart my wife's 1991 convertible. Does anyone know the gauge of the factory power wire and fuse going to the trunk amp? Would it support a 4x75rms aftermarket amp?
          Thanks for any info!
          • petercory
            • Jan 2021
            • 16
            #575
            I just pulled the Sony Head Unit out of my '90 Conv. and found that the Speaker Grounds were not connected to the Head unit; all (4) were connected together and not grounded to anything. I have completed the Amp Bypass and now I'm planning to install a CD43 Business CD. Should I leave the Speaker Grounds the way they currently are, connect them to a common ground or attach them to the corresponding ground wire on the CD43 Business CD Harness or are other changes required?
            • bradnic
              • Jul 2012
              • 3551
              #576
              petercory are you running the factory amplifier?
              HOWTOs:
              OEM Keys
              MTech1 docs
              88 ix Lach/Card
              91 ic Calypso 3.1
              86 Cosmo 2.7
              OEM+ or bust!
              • bradnic
                • Jul 2012
                • 3551
                #577
                Originally posted by e30mobber
                used this and worked absolutely perfect in my 91 325i coupe with premium sound and no fader, perfect amp delete write up and sounds fantastic > thanks guys
                here’s the work> piece of cake (00=00)
                Really wish folks would stop cutting 30+ year old OEM audio wiring. I have bypass adapters now - just plug in to the amp connector and instant bypass. Also have access harnesses to run aftermarket amps, subs etc.
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • petercory
                  • Jan 2021
                  • 16
                  #578
                  No, I've done the Amp Bypass
                  • petercory
                    • Jan 2021
                    • 16
                    #579
                    After carefully following the E30 Premium Sound System Amp Bypass instruction posted by numerous forum members throughout this thread and isolating the ground wires at the 17 pin connector, my CD43 Business CD would still not transmit sound through the original Speakers. All of the Speakers tested good @ just under 4 ohms. Fortunately "bradnic" had the patience to explain why the "Cut & Cobble" procedures weren't a proper solution, I purchased his Bypass Adaptor and wiring kit for the front Speakers; once installed, my system functioned perfectly. I could have saved many hours of wasted time and frustration had I purchased a "Kit" from bradnic to begin with.
