Have a '90 Conv W/Premium Sound & no Fader. I've done the Amp Delete Bypass. The Kick Panel & Rear Speakers work ok, but the Tweeters just have a low pitched noise when the other speakers sound normal. Do the Tweeters have to be re-wired?
Radio Wiring and Amp Bypass
This is a sticky topic.
Did you change the front kick panel speakers? They have a crossover on them for the tweetersI BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
I just pulled the Sony Head Unit out of my '90 Conv. and found that the Speaker Grounds were not connected to the Head unit; all (4) were connected together and not grounded to anything. I have completed the Amp Bypass and now I'm planning to install a CD43 Business CD. Should I leave the Speaker Grounds the way they currently are, connect them to a common ground or attach them to the corresponding ground wire on the CD43 Business CD Harness or are other changes required?Comment
petercory are you running the factory amplifier?I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Really wish folks would stop cutting 30+ year old OEM audio wiring. I have bypass adapters now - just plug in to the amp connector and instant bypass. Also have access harnesses to run aftermarket amps, subs etc.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
After carefully following the E30 Premium Sound System Amp Bypass instruction posted by numerous forum members throughout this thread and isolating the ground wires at the 17 pin connector, my CD43 Business CD would still not transmit sound through the original Speakers. All of the Speakers tested good @ just under 4 ohms. Fortunately "bradnic" had the patience to explain why the "Cut & Cobble" procedures weren't a proper solution, I purchased his Bypass Adaptor and wiring kit for the front Speakers; once installed, my system functioned perfectly. I could have saved many hours of wasted time and frustration had I purchased a "Kit" from bradnic to begin with.Comment
