This is actually a little strange. ONLY the speedo itself is not working - the needle just stopped moving yesterday. The signal to the OBC and ECU still work, the odometer still works - so the VSS is fine (I actually just replaced the sensor because it was broken).
None of the other gauges are dead - the econometer still works too (which requires a VSS input to function). the SI lights seem to work fine, but as far as I know, the batteries have never been replaced.
I'd actually planned on removing the cluster for a bunch of other work to it so it's at least good timing, but what is most likely? I'm not against replacing the SI board since I'll have it out anyway. Solder joints? Anyone ever see only the speedo needle stop working?
