amp settings
  • u3b3rg33k
    • Jan 2010
    • 2452
    Originally posted by jrobie79
    think i figured it out, since i bridge the amp and only put RCA's into channel 1 and 2 its not right, if i put Y's on it and put an RCA in each channel 1,2,3,4 i believe that would help? correct me if im wrong
    My amp only uses the L channel input in bridge mode. Are you using the correct input?
    Which orion amp are you using? Please post a link / model number.
    Ich gehöre nicht zur Baader-Meinhof Gruppe
    Originally posted by Top Gear
    Just imagine waking up and remembering you're Mexican.
    Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
    • jrobie79
      • Mar 2006
      • 2525
      HP-4600 4 channel
      1991 318i ---- 308K - retired
      • bloodshot-e30
        • 1494
        ill look it up real quick
        ^Back in the game^
        BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
        FS thread:
        http://www.r3vlimited.com/board/showthread.php?t=214105
        • jrobie79
          • Mar 2006
          • 2525
          • bloodshot-e30
            • 1494
            yea u need to have BOTH inputs on this amp hooked up fo it to work properly
            ^Back in the game^
            FS thread:
            • jrobie79
              • Mar 2006
              • 2525
              so I need a Y cable to split my RCA's then correct?
              • bloodshot-e30
                • 1494
                u can do that or just runs another set of cables.
                are u running ALL 4 speakers off this one amp?
                ^Back in the game^
                FS thread:
                • jrobie79
                  • Mar 2006
                  • 2525
                  no, just the front, no speakers in the back
                  • u3b3rg33k
                    • Jan 2010
                    • 2452
                    I would suggest you hook up an ipod set to 70% output via the RCA cables that feed the amp and if you get good sound, then you know what to look at. Try another set of RCA cables (known good) if it's still quiet. Then, if it's still quiet just turn up the "gain" on the amp (which may be more of an attenuator) until it does what you want.
                    It wouldn't hurt to check the speaker - amp connections as well, make sure there's no stray strands of wire touching things they shouldn't be.
                    I'm a bit confused by that input mode switch, it gives the impression that it does either channels 1 and 2, or 3 and 4. Where's the 1,2,3,4 setting?
                    NM:
                    11. Input Mode - 1/2 channel or 3/4 channel selectable. In the 1/2 CH position, the input to channels 1 and 2 are also supplied to channels 3 and 4, respectively. In the 3/4 CH position all 4 channels are supplied separately When the switch is to the left (4 CH position), front and rear inputs are independent. This allows a source unit with an internal fader to fade between the 1/2 CH and 3/4 CH outputs.
                    • bloodshot-e30
                      • 1494
                      if your only using the fronts then set the front input up and dont bridge it and see if that helps.
                      ^Back in the game^
                      FS thread:
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        Where are you getting this information? I am unable to verify it, and from past experience would say that's nonsense. The manual says nothing about needing to have two inputs attached, and if what you're saying is true, then fading entirely left would cause the amp to malfunction, which I doubt is the case.
                        Just because the amp doesn't have a single channel mode doesn't mean it won't function properly with signal on a single channel only.
                        • bloodshot-e30
                          • 1494
                          his is a 4 channel amp BUT has RCA inputs kinda likt to amps in one. i used to have one like this but to bridge it i had to have all RCA's hooked up.
                          also im not sayin its fading left. but if it needs to be turned up THAT loud for the speakers to be loud then something is messed up. could be the amp speakers or headunit.
                          ^Back in the game^
                          FS thread:
                          • u3b3rg33k
                            • Jan 2010
                            • 2452
                            his is a 4 channel amp BUT has RCA inputs kinda linked to amps in one. i used to have one like this but to bridge it i had to have all RCA's hooked up.
                            If that's what you meant, then that's pretty common. They just have some resistors wired in on the high line. if you open it up, those inputs go straight from the high line to resistors, and then into the RCA line. They are not separate (which is why they tell you not to use both at once).
                            The fading left thing was a comment about possible operation, not how OP's is or is not operating now.
                            • StereoInstaller1
                              GAS
                              • 22679
                              Press that little button so that it is in 2 channel mode, then use the inputs for 1 and 3 (only the left channels) then check your balance. If you do not have proper left/right, PM me.
                              Luke
                              Closing SOON!
                              Thanks for 10 years of fun!
                              • jrobie79
                                • Mar 2006
                                • 2525
                                thats how its hooked up right now, channels 1 and 3, with the button pushed to 1/2 channel
                                edit: nvm, i think its set up to channels 1 and 2, will change it tomorrow and see what happens
