Project: Door Speakers
  • StereoInstaller1
    GAS
    • 22679
    Originally posted by element6
    I'm throwing a set of these on.. I suck with glass.
    http://cgi.ebay.co.uk/BMW-E30-Door-s...#ht_988wt_1139
    How much is shipping?
    Remember, if you have a late model, all you need to do is cut a hole, it ain't that hard.
    Closing SOON!
    Thanks for 10 years of fun!
    • kinvodA
      • Sep 2009
      • 278
      How is the finish on these?
      "Wow. We're just blowing through nap time, aren't we?"
      • Hey-U
        • Mar 2008
        • 560
        Cut a hole? Can you explain more?
        • soupiemelody
          • 188
          Originally posted by hey-u
          cut a hole? Can you explain more?
          +1
          1991 318i Past
          1990 325ic Past
          1998 540i/6 Past
          1988 325ic Present
          1998 M3 Present
          2000 M5 Present
          • jaywood
            • Jul 2010
            • 4528
            +2
            • jrobie79
              • Mar 2006
              • 2526
              I have a set of PPI 356cs, and a late model e30.....sorry no pics at the moment but heres what I did....
              I took the door skin off and figured out the best location above the map pockets where there was nothing behind the metal.
              Then I traced the provided template and use an air cut off tool and cut the door metal an corresponding position in the door skin.
              My speakers came with a metal ring that had 4 threaded holes, which i stripped the paint off and welded to the doors, then I drilled 4 holes in the door skins that matched up with the threaded holes in the metal frame, and voila, speakers mounted.
              Then to secure the grill cover/holder whatever the hell its called I used 4 self tapping metal screws to hold the grill cover on and bam, well above my knees and great sound
              1991 318i ---- 308K - retired
              • Dozyproductions
                • Jan 2007
                • 4682
                I want to put the midrange from newer gen into my car for I heard it was marvelous. How do you like the 2way set and do you have any pics?
                • Dozyproductions
                  • Jan 2007
                  • 4682
                  How big of a driver are we talking about here though luke? Im looking to put in an anarchy mid :twisted:
