E34 box paid for :) Thanks Luke!
Got Bass? Spring box build is here! E34s too!
Just got around to opening up my box last night! Thing is looking beautiful. Going to install today or tommorrow.
Could you update the install thread? Or am I the only dumb one who thinks it could use some more specifics?
First dumb question, just realized there is no terminal, how do you suggest running wires out? I really dont wan't to cut into this thing of beauty, but drill a hole run wires then seal with silicone? Also somewhat unsure of where put the screws that secure the box in place. Might start a thread on where to put my amp.West German BMWs, they just don't make the same as they did before the wall fell.
^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
search "buttcrack" in thread titles, this will turn up: http://www.r3vlimited.com/board/show...ight=buttcrack
I think I showed where/how to drill a hole for the wire.
I hate terminal cups. The good ones aren't in the budget and the cheap ones melt and are weak.
About the sparse info, yes, you are right. I WILL be doing websites, I own 2 domains (with 3 years of godaddy hosting) and am taking a seminar on WordPress and "social network marketing" in april. www.germanaudiospecialties.com will sell products, and www.bimmerboxes.com will focus on installation tutorials and finished installs.
I keep hoping to see someone do nicer stuff...errbuddy gets lazy on the looks!
Later, I will be selling complete amp racks, pre-wired to your specific amp configurations.
AFTER the 10 channel crossover gets done, after the hiring of 2 or 3 bright hard working guys who want to eventually run a tiny empire.
After R3Vpocalypse, too.
Originally posted by Rodoni View PostQuick question. It sounds like the issue with the e36 is the back seat and how tight it seals and the shape. Could you make an e36 box for an e36 with a rear seat delete? I don't run a back seat in my m3, just upholstered plywood 8)
A pic of it all:
You really do miss that sub, huh?
Thanks!
Luke
hey, bf.c member here. interested in giving the stereo in my e34 a little extra kick.
i think im going to go with one of the subs you suggested
depending on if you have another 12" box for e34.
Im looking for an amp to go with it. I know i only need a single channel and dont really need anything over 300w but im confused as to how websites list that an amp is 1000w but single channel is only about 430 or 290 or something. Im new to any kind of speaker systems and wiring, but i was looking at
is there a better alternative than this?
I added you on facebook to place an order, im Karl btw :D
Thanks for the amazing effort you put into the community!
Originally posted by Blaine0002 View Posthey, bf.c member here. interested in giving the stereo in my e34 a little extra kick.
If it's a cheap amp they are advertising peak power, which is worthless. Whenever you see "max power output" or "peak power output" ignore that number.
Originally posted by StereoInstaller1 View PostI keep hoping to see someone do nicer stuff...errbuddy gets lazy on the looks!"A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
87 325 Daily driver Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
92 325ic Sold & Re-purchased
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i Sold
Blaine. That amp is great. I have it in my e30 running the obcon. You could even get the 900. The 1050 puts out 290W rms at 4 ohms to the obcon and the 900 is 230rms. If you are getting the 12inch obcon go with the 1050. I have it powering my 10 and it does a great job.Team Hybrids
Anyone else who purchased a 12" box having install problems? I can't get my port holes to line up quite right... I put my problem in the V2 box install thread, but just was wondering if anyone else from this batch is having problems.West German BMWs, they just don't make the same as they did before the wall fell.
We can discuss it on this thread, the install thread or PM. The trunk tar is what is in the back of the trunk correct? yeah I removed that, I can shoot some more pictures though to try and figure it out. On the install thread I put the picture of my holes, they seem to match your holes. But the driver's side just isn't lined up its about a half inch off like the box is in the wrong position and I need to slide it over but I can't slide it over because the passenger side port lines up great. I cut the holes on 2 vehicles and they both are the same as far as the drivers side not lining up.
EDIT: or maybe I should make my own thread about the issue, this thread's already a little heavy at going on 17 pages, but if you want to keep it on this thread, could you post some measurements to make sure I've got everything right?
Whats the distance between the 2 drilled holes in the car? What is the distance between the ports on the box? Distance from the left port to the left edge of the box, distance from the right port to the right edge of the box? Because I'm measuring and it doesn't seem that the ports on the box are perfectly symmetrical, not sure if they are supposed to be or not.Last edited by NeoMishMoo; 03-26-2011, 11:43 AM.West German BMWs, they just don't make the same as they did before the wall fell.
The ports are NOT symmetrical, they can't be, as the box has to be offset to accommodate the power wire on the left side of the trunk.
Note that they are symmetrical to the woofer mount, which is not centered on the box either.
I don't have measurements with me, but I will get them to you.
The trunk tar is the layer of heavy (57 pounds) thick tar UNDER the carpet, all over the bottom of the trunk on 6 cylinder cars.
