Do I need resistors for dome light LEDs?
  • ac3
    • Jan 2011
    • 121
    Or can I just swap in a led bulb of the same style and call it a day?
  • ac3
    • Jan 2011
    • 121
    And any idea if this electronic flasher would work in an e30? Thanks.
    Electronic LED Flasher Relays have no minimum load-12VDC. Eliminates the need for load resistors, turn signals will flash at normal rate with or without LED bulbs. Use the Flasher Selection Guide to determine the correct Flasher Relay for your vehicle.
    • jrobie79
      • Mar 2006
      • 2525
      pretty sure you need a resistor, my dad (electrical engineer) pretty much did my whole conversion for dome lights and license plate lights, but i know he soldered resistors in there somewhere inline. make sure you orient the LED the right way, diodes have one way power flow...
      1991 318i ---- 308K - retired
      • DaveSmed
        • Apr 2007
        • 1407
        No you do not.
        -Dave
        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
        Need some help figuring out the ETM?
        • jrobie79
          • Mar 2006
          • 2525
          i stand corrected... i dunno what my dad was wiring, but I know he used them
          • pandaboo911
            • 2070
            I got some LEDs that run on 3 volts each, hook 4 of em up in series and you dont need a resistor. Really depends on what LEDs u use.
            It says those flashers run on 10-15v, so you can hook one up without a resistor, or multiple in parallel.
