Luke - recommend me a good 4ch wiring kit
  • Jean
    • 18228
    Would like to get the amp/sub/box/deck/speakers installed.... I found a $30 kit on amazon, but it's only 2ch.... what do you recommend?
    http://www.amazon.com/PK4Z-Gauge-Pow...f=pd_rhf_p_t_1
    I would like something with "thin" rca cables for ease of install, 4ga would be nice for power but 8ga would probably work as well.
    1 4ch amp, will drive front stage and rear two channels bridged will drive a single 12 in your box.
    My e34 has battery upfront...
  • Mikhail Bakunin
    • May 2011
    • 126
    http://www.sonicelectronix.com/item_...4-09ZCK84.html
    http://www.sonicelectronix.com/item_...AMP48-RCA.html
    • StereoInstaller1
      GAS
      • 22679
      Holy fuck, talk about overpriced garbage! The Kicker is OK wire, but $80 for 8 GA? Kiss my ass! And the Tsunami shit should be about $50, max. Their distribution blocks are made of the same shit as a softball league trophy. They strip, they corrode, they are absolute crap.
      Jean, get 3 pairs of the "Premium" RCAs from monoprice.com and grab a hunk of 4ga and a AGU fuseholder (ANL if you want burly) from a local shop. Get enough that WHEN you add to the system (not if, fucker, WHEN) you won't have to run more wire, so make sure you can drop a distribution block or whatever then.
      See if you can get 100% copper wire, as copper-clad aluminum is most common these days.
      Closing SOON!
      Thanks for 10 years of fun!
      • Mikhail Bakunin
        • May 2011
        • 126
        It's all the same junk.
        • Jean
          • 18228
          I was looking for a good deal, I can spend $100 on kits locally all day long :)
          • Jean
            • 18228
            Luke - http://www.sonicelectronix.com/item_...k-AKIT-44.html + another set of RCA cables yeah?
            • Jean
              • 18228
              hmm
              3x http://www.sonicelectronix.com/item_...sche.html#tabs
              or
              http://www.sonicelectronix.com/item_...Link-CK4Z.html
              + 2x rca sets.... only comes out to about $50 shipped
              • jrobie79
                • Mar 2006
                • 2526
                I found a welding supply company online, its all pure copper cable, i got 2 gauge which is probably overkill, but it was wicked cheap, like 20 cents a foot, IIRC. And just used some RCA's i got at tweeter before they went out of business, plus a distro block on ebay. Its held up fine and witht he bigger wire I can upgrade if i need to, just might need to swap some fuses.
                1991 318i ---- 308K - retired
                • 5Toes
                  • 9836
                  Monoprice RCAs are the best for the price. DONT TRY ANYTHING ELSE
                  • Jean
                    • 18228
                    Monoprice cables are thick and reported as hard to bend , the price is about the same as Scosche
                    http://www.sonicelectronix.com/item_...y-Scosche.html
                    http://www.monoprice.com/products/pr...seq=1&format=2
                    • 5Toes
                      • 9836
                      They aren't that bad, and the connectors are MUCH better. The insulation is thicker. You dont need to bend them THAT much
                      • Mikhail Bakunin
                        • May 2011
                        • 126
                        Ok - since you posted this on the internet, it must be true.
                        • jwth2005
                          • Apr 2007
                          • 60
                          Not to be a dick here but i would be 100 times more inclined to listen to stereoinstaller's advice(which is what i would have recommended over buying ANY kit anyway) being that he is a professional and not to mention a moderator, than i would your advice. So i would think about that before putting someone else down.
                          I will reinforce what luke said. Amp kits are overpriced for what they give you and the quality just isnt there.
                          • 5Toes
                            • 9836
                            Well you could listen to me too. I JUST saw Luke yesterday, him and I looked at the stereo on my car. I have used monoprice for cables in the past, look all over the web, they are highly regarded.
                            People spend $35 on 6 foot rca cables, http://www.bluejeanscable.com/store/audio/index.htm
                            • jwth2005
                              • Apr 2007
                              • 60
                              Lol yea that was meant to support both of you. There is no point in spending so much money on RCAs.
