battery shorting out after motor swap?? whats the deal?
  • tfritz
    • Jan 2008
    • 590
    Just swapped an m20 into a clean shell and have been driving it for about a week. Today I noticed the battery making a whining noise and was bulged and leaking acid. I immediately removed the battery to clean up the mess. Anyway, I put another battery in the car and drove the car for about a half hour. I just looked in the trunk and the new battery is leaking acid. Whats the deal? I need help!!!
    Thanks.
  • tfritz
    • Jan 2008
    • 590
    nobody?? Does anybody have a diagram of the main power distribution junction in the engine bay?
    Thanks
    • AndrewBird
      The Mad Scientist
      • 11898
      Check the voltage at the battery with the car running. Should be ~14v. Sounds like maybe the alternator is over charging the battery.
      • tfritz
        • Jan 2008
        • 590
        Thanks, just checked that and its about 17v. Guess I need to source another alternator.
        • genocide98
          • Oct 2009
          • 106
          You may want to check out the alternator itself before buying another. It may just be the voltage regulator or diode pack. I'd attempt to troubleshoot your charging system, double check all grounds and connections, test components, etc. A regulator or ground strap < entire alternator.
          • tfritz
            • Jan 2008
            • 590
            It was the voltage regulator, got it replaced.
            Thanks
