Hum / whining noise through speakers.
    Hey guys I just recently finished my audio install in my e30. Today I noticed though that I am having a small bit of a/c hum/ whining noise coming through my speakers. Its a bit louder when the air conditioning is on. I have everything grounded and it sounded great but now Id like to eliminate that noise as its very annoying.
    Could the stock ground wire that I crimped on the back head unit for ground be bad? Do you guys usually make a better ground for the head unit? Any options to fix this issue would be greatly appreciated.
    Thank you.
    The ground may be fine. How are signals routed (how are you getting signals from the HU to the amp in the trunk)?
    Transaction Feedback: LINK
      I have the rca's running through the center console to the rear. And the speaker wires running along both doors to the 4 channel amp. Hopefully some pics will help?
        Does the whine change tone with engine speed?
          Yes, when I rev my engine it gets louder and a higher pitch.
            What gear do you have?
            Closing SOON!
            Thanks for 10 years of fun!
              try grounding the rca cables to the metal casing on the head unit with some thin wire i had the same thing with mine i think its the alternator but after i ground the cables it was gone
              87 325is
                This is an ooooold installer trick. If it works, it also means your deck is bad.
                Closing SOON!
                  check your RCA cables. I had the same problem on mine. Turned out to be bad RCA's. Also how much gain do you have on your amps right now? you could be amplifying the noise too.
                    rca are fairly new monsters. The head unit is brand new. Ill check the gain and report back. Luke 4.10 auto.
                      I meant AUDIO gear
                      Closing SOON!
                        Sorry Luke I misunderstood.
                        Alpine mrv f353 as my 4 channel, and jl amp for my subs that is bridged. ( I will get the model number later ) Two kicker comp vr's ( dual voice coil. All monster speaker cable, remote and rca's. And the new pioneer deh-6300ub as my head unit. Ill snap some pictures today of my setup.
                          bump for update cause im having the same problem
                            Sounds like your car is haunted. Does the whining sound German? If it tells you to invade Poland, don't do it.
