engine cutting out with aftermarket headunit
  • pantelones
    • May 2011
    • 533
    my engine is cutting out with the aftermarket headunit that the PO had installed in the car (87 325e). i know thats it's due to the headunit drawing to much power, and when i get on the throttle it interferes with the amount of spark the engine gets. what he said to do is connect the headunit to the positive terminal up front for more power. is this the proper way to do it? im sure that this is a common problem, so if anyone knows, or can post a link to a thread that explains this it would be much appreciated. im searching as you read this, but im just trying to speed up the process of finding the answer. thanks in advance!
    A man chooses, a slave obeys... Would you kindly?
  • AndrewBird
    The Mad Scientist
    • 11897
    There is no way the head unit would draw enough power to cause the engine to cut out. Something is wired wrong. Pull the deck out and take a look. I recommend using the stock wires for everything. They are plenty adequate enough.
    • Stoner Sam23
      • 186
      Sounds like someone wired the head unit power to the ignition.
      • pantelones
        • May 2011
        • 533
        yes it does. damn, i knew that there was something fishy about him telling me to give it more juice. ill have to take it out and have look.
