Radio problems
  • Deadskittles
    • Jul 2011
    • 140
    Radio problems
    I was recently working on installing a new radio in my 84 318i and i had just finished wiring it, turned it on and it worked. Then i put the radio into the slot and started up my car and blam, no dice not only did the radio not work my speedo also went out. Also the power wires for the radio were not giving off voltage. Im pretty new to E30s so i was wondering if anyone had any insight or advice. Thanks!
  • StereoInstaller1
    GAS
    • 22679
    My guess is you have improperly insulated the wiring, and have now caused a short, thus popping a fuse.
    Have you taken it back out to inspect?
    Closing SOON!
    Thanks for 10 years of fun!
    • GunMetalGrey
      • Dec 2010
      • 1499
      Describe the problem better
      • ethrtyiS
        • 8147
        sounds like fuse 12 is blown. always disconnect battery when working with anything electrical.
        「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
        「my feedback thread」
        • Deadskittles
          • Jul 2011
          • 140
          After the radio and speedo stop working i checked the fuses however when you guys said to check them i decide to recheck specifically 12 and yes that fuse was toast i must have accidentally missed it, Thank you very much.
          • mr.vang
            • 4371
            hahaa..fuse is always the first thing to check before anything else
