help me diagnose power windows, sunroof, and a/c
  • ethrtyiS
    • 8147
    not sure what happened but all of a sudden my sunroof and windows stopped working. the buttons don't illuminate whatsoever. it's definitely not the breaker switch as it doesn't control sunroof nor explains why they don't illuminate. also my a/c stopped working at the same time. blower motor doesn't fire up nor do the a/c and recirculate buttons light up.
    i have checked all related fuses, 17 + 20, they are fine, replaced them, still nothing. are there any relays or something i can check and where are they located? anybody have a clue on what it could be? help me diagnos this thing!
    「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
    「my feedback thread」
  • nrubenstein
    • 3148
    look to the unloader relay.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • ethrtyiS
      • 8147
      where is this unloader relay located?
      • nrubenstein
        • 3148
        search. it's part of the starter.
        • ethrtyiS
          • 8147
          i'm not at a computer. and it's very difficult to search on my phone. i've tried and i'm getting nothing. where would i look?
          • ethrtyiS
            • 8147
            okay so i believe i found them, k5+k7 right? should i replace both the relays? or do i need to replace my starter?
            • ethrtyiS
              • 8147
              bump, can anyone help me out. i need my windows and ac working again!
              • twistednut
                • Nov 2007
                • 272
                Disconnect the wire on the starter with the smallest nut (8mm). Turn the key to the on position, turn the fan blower on and touch the wire to ground. If the fan fires up then it is your starter.
                what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
                • ethrtyiS
                  • 8147
                  so my starter is going bad? i've never replaced it since i've owned it and everything has been fine. i am going to try swapping relays and hope that fixes it. is there a way to bypass and ground it elsewhere rather than replacing the starter?
                  • ethrtyiS
                    • 8147
                    well i solved the issue. traced all wiring to fuse box and turns out po spliced into the power wire from the alternator and it had frayed away and came apart. used some shrink butt connectors and wrapped it wiring tape. all fixed.
