Vert sub idea.
  • noahp45
    • Jun 2011
    • 107
    Vert sub idea.
    So I know that the idea of puting a sub in the back was a no-go. I was thinking since my E30 has no armrest, maybe someone could make a 8" sub box that acts like a armrest between the driver and passenger? What do you all think?
  • achtunge30
    • Apr 2006
    • 1029
    I plan on sticking an Infinity BassLink behind the driver seat - self amplified and removeable in a pinch if I need the back seat.
    - Frank
    '87 325ic M-Tech 1 For Sale!
    http://r3vlimited.com/board/showthread.php?t=407503
    Build Thread http://www.r3vlimited.com/board/showthread.php?t=229347
    • noahp45
      • Jun 2011
      • 107
      I herd of that plan, but don't those baselinks just sound like factory?
      • aworthybrother
        • May 2007
        • 899
        basslink sounds more better than factory.
        • DRTSRFR
          • May 2008
          • 1836
          The Basslink actually makes pretty good bass, but it's big and won't let you slide the seat back if you're tall.
          For the time being I installed a compact self amplified Lanzar 8 behind the drivers seat. It won't rattle the windows but does OK to give some fill.
          In a nutshell, it's junk, but does the job for about $125.
          Suspension tips here...
          http://www.r3vlimited.com/board/album.php?albumid=757
          • noahp45
            • Jun 2011
            • 107
            Well I have a 8" kicker sub that I put in a bazooka tube. I think i'am going to put in on the middle hump between the driver and passenger seat to see how it sounds
            • reelizmpro
              • 9556
              I've got an 10" alpine sitting in the backseat. It's not elegant but for now...it gets the job done. There's really not a lot of room in the footwell behind the front seats on the verts. I like the idea of the armrest box. Sounds like a good alternative to the glove box sub and hidden subs under the rear seats with removable cushions.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • DRTSRFR
                • May 2008
                • 1836
                Ahh the glovebox sub...
                Who's dumb idea was that?
                • StereoInstaller1
                  GAS
                  • 22679
                  Mark, did you ever get that all finished up?
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • reelizmpro
                    • 9556
                    Luke,
                    How about an in-cabin box that'll sit in the middle of the rear seat like an armrest for a single 8" woofer. I was thinking front firing, ported for max output, and you could even use that area between the rear ashtray and rear seat. It wouldn't be WIDE but it should be long enough to give good bass.
                    88 M3 - LACHSSILBER
                    • LiLBimmE30
                      • Aug 2011
                      • 22
                      Sounds like a sweet idea, I'd be interested.
                      Luke,
                      92 325i Schwarz II Vert
                      • talltorontoguy
                        • Apr 2006
                        • 267
                        I like the idea. Has anyone ever successfully modified rear side panels to accept a pair of thin 8" woofers? I'm thinking of widening the panels so there is no armrest on the sides which will give another 3" or so of clearance.
                        Winner - Best Engine, Bimmercruise 2010
                        Runner Up - e30 Wild Category, Bimmercruise 2010
                        Winner - Best Cabrio, Trillium @ Tedfest 2011
                        Winner - e30 Wild Category, Bimmercruise 2011
                        www.vertnation.com
                        My car in Berlin Klassic promo video
                        • StereoInstaller1
                          GAS
                          • 22679
                          Exactly what I would do if I had a vert...
                          Closing SOON!
                          • talltorontoguy
                            • Apr 2006
                            • 267
                            Time to bone up on my fabrication skills. Recommended drivers?
                            www.vertnation.com
                            • reelizmpro
                              • 9556
                              The problem with that is...1) there's barely enough room for a 5.25" speaker so imagine trying to fit a shallow 8" sub. Even if you extended it 3" (which realistically is quite a bit on an already narrow seat) or so it would still be pretty damn tight and there's also power windows back there. 2) there would be no rear midrange speakers at all. 3) There's also the issue of the top latch being accessible for those with manual tops.
                              I think the center armrest sub would be cheaper and easier to implement and it would also be removable as well which is always a bonus. It might not look as "clean" but it makes the most sense.
                              88 M3 - LACHSSILBER
