The E30 Aftermarket Alarm Installation Writeup
  • 84driver
    • Aug 2011
    • 234
    Thanks Dave, I hadn't heard that before about the handle and the relay. I'll give that a shot when I open up the kick panel. And thanks Luke for the pics, this thread is becoming quite informative!
    As for the diagram software, it looks like the Windows link from the QUCS site goes to the wrong download. You should be able to download the Windows .exe installer from this link on Sourceforge.
    balticblau-metallic '84 318i 5spd 3.91 LSD
    • 84driver
      • Aug 2011
      • 234
      Updated diagram, now badly colored with Photoshop.
      I'm also strongly considering putting the trunk release relay next to the actuator in the trunk so that I can power it off of the power door lock fused circuit. Also then I won't have to run a 15A line all the way to the trunk, just the trigger.
      • StereoInstaller1
        GAS
        • 22679
        You don't have a constant +12V at the actuator, but the amp and the antenna are both close.
        I really wanna see what you can do with the trunk pop. I have spent several hours looking at latches, both in and out of E30s. I gave up years ago, but have always loved trunk pop.
        Closing SOON!
        Thanks for 10 years of fun!
        • airkhin
          • 593
          Im subscribing to this thread as I've been wanting to do an install for a while!!!
          • Court M3
            • Jan 2004
            • 6713
            Nice writeup! Luke did mine as I hate wiring on my own time. Been chasing trons for the last 19 years active duty.
            BTW If your girl wants an X3 mine is for sale (shameless plug)
            Continuous For Sale Thread
            323i s50
            • 84driver
              • Aug 2011
              • 234
              Thanks Court, I'm not a pro so feel free to suggest any improvements. I think she's stuck on an X5 but I'll keep your offer in mind.
              Updated the first post with prewiring photos. I didn't wire up the trunk release yet, that'll happen late this week when my 524N actuator and my Z3 antenna arrive.
              Not yet noted on the diagram is the Scytek G20's black wire on the same plug as the red 12v, yellow ignition, and white parking light wires. That black wire I'm sure goes to ground although it is not described in the Scytek manual or diagram.
              Not sure yet where I'm going to mount the LED. Any suggestions? I've seen some people use the E36 OEM alarm LED mount but that is a hassle. I know there is a door installation method (by the lock) but I'm wary of cutting a hole in my door vinyl. Also not sure that just drilling a hole in a switch blank will look clean enough... More photos and description coming soon with the install!
              • bmwstephen
                • 2463
                Black is ground i confirmed with scytek on my unit
                -Blame my typos on my fat fingers & Droid Charge
                • StereoInstaller1
                  GAS
                  • 22679
                  A fairly easy way to mount the LED is to strip all of the outer "bezel" off of it, drill a hole in a blank plate (or just below the lighter, left of the ashtray) just big enough for the bare LED to poke through, then a tiny drop of crazy glue on the backside to hold it in place.
                  I prefer the door LEDs myself, I generally do them on every car I own. BTW, I have lots of Scytek LEDs in stock, both blue and red. If anyone really needs one, I might be willing to hook you up cheap.
                  Maybe.
                  Luke
                  Closing SOON!
                  • DaveSmed
                    • Apr 2007
                    • 1406
                    Hmm.... Putting the diodes in series to increase their current rating doesn't sound right. Think you might have wanted parallel.
                    -Dave
                    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                    Need some help figuring out the ETM?
                    • StereoInstaller1
                      GAS
                      • 22679
                      BTW, you do not need to diode isolate the 2 sides. Myth: busted.
                      All it will do is parallel the 2 sides of parking lights. On a US car, no worries, the switch does not care.
                      If you want to use a euro parking light switch, use diodes.
                      Closing SOON!
                      • 84driver
                        • Aug 2011
                        • 234
                        I'd definitely prefer a red LED over the blue one which came stock. Is there a chance you have a pic or two of the door LED installed?
                        You are right. I don't know where I read and retained this bad advice... now I know that diodes in series increases their voltage rating. Also I read that diodes in parallel are likely to fail, I should have used 6A diodes if I needed them.
                        Bummer, definitely wasted some time on this one. I'll clip it out and save the diodes for a hood pin trigger, or something...
                        • StereoInstaller1
                          GAS
                          • 22679
                          You can run a pair in series and lose virtually nothing in brightness.
                          Closing SOON!
                          • DaveSmed
                            • Apr 2007
                            • 1406
                            Luke, your using domestic manufacturer reasoning there!
                            The left/right split is primarily for the city parking lights in euroland, but it is also fairly important when your crapcan starts having issues from it's half-ass radio install and pops fuse 23. Fuse 22 is still good and isolated from that failure and you at least have some lights on the back of the car.
                            The domestic approach is to have the rear lights share the fuse with the dash lights so in the event of a failure, the driver hopefully notices the lack of lighting in the instrument panel.
                            -Dave
                            • 84driver
                              • Aug 2011
                              • 234
                              Luke, nice door install photo. Perhaps I will do that after I get the red LED.
                              Dave, are you in agreement with Luke (no diodes necessary) ? Not sure which way to read that :)
                              • StereoInstaller1
                                GAS
                                • 22679
                                Dave makes a good point that you likely should use diodes, but I don't on my own cars.
                                Closing SOON!
