Multi-function clock harness/connector
  • FreedS4
    • 752
    Need a favor from someone who has the multi-function clock in an 89 e30. I spliced in the harness for an analog clock a while back, but would like to go back to the multi-function clock. Would someone mind taking a picture of the harness, at the connector so I've got a visual of where all the wires go to get the MFC working again? Thanks, I appreciate it.
    Chris
  • FreedS4
    • 752
    From the top of the connector (the part that looks like a T, where the zip tie is),
    Empty Empty
    Empty Blue
    Empty Brown/Yellow
    Empty Empty
    Empty Brown/Blue
    Grey/Purple Brown/Red
    Then I have brown, brown/white, grey/white, and red/white wires left. Which empty spots do they occupy? Thanks
    Chris
    • FreedS4
      • 752
      Just need someone to snap a quick picture of the harness. Anyone, a little help?
      Chris
      • FreedS4
        • 752
        Anybody?
        • jaywood
          • Jul 2010
          • 4528
          I've got a '90 325i. Not sure if it's the same. I can take a pic tomorrow most likely
          • FreedS4
            • 752
            I'll be able to tell by where the wires are on your connector. I really appreciate it. I've been trying to get this wired back in for over a week now, but haven't found any good info on wire color and placement yet. Thanks again.
            Chris
            • FreedS4
              • 752
              Still looking for someone to take a couple minutes to help me out. Just need you to take a picture of both sides of your harness connector so I can make sure I'm hooking my wires back up correctly. Thanks
              Chris
              • FreedS4
                • 752
                Still looking for a little help. It'll only take 1 minute.
                Chris
                • 3toedshewie
                  • Aug 2011
                  • 364
                  can I help?
                  I got a 325iC 92 convert, will that be the same?
                  -nik
                  Lieben Sie Schlangen ?
                  • FreedS4
                    • 752
                    -nik
                    Maybe, mind snapping a couple quick photos of the harness connector? I'll be able to tell right away if it'll help. I had someone snap photos of a '91 318i harness and the wires were in completely different spots and were different colors, but we'll see. Thanks for your help, regardless.
                    Chris
                    • 3toedshewie
                      • Aug 2011
                      • 364
                      no problem, gotta find that connector first, should have a pic weds night
                      • FreedS4
                        • 752
                        Perfect, thanks again!
                        Chris
                        • FreedS4
                          • 752
                          Bueller?!?!
