alternator bypass light
  • TG Goose
    • Jul 2011
    • 234
    I'm doing a custom gauge cluster in an 1984 E30 and need to bypass the alternator warning light. I still want to wire in a light, as I am keeping the stock cluster housing, and I need the alternator to keep charging my battery.
    Just wondering what people have done in this situation before.
    ______________________________________
    1984 LSB 318i - Sold
    1986 325i - Motor Swapped Track Car Project
    1995 318ti - Sold
    1999 540iA - Daily Driver
  • AndrewBird
    The Mad Scientist
    • 11898
    So, you don't want to bypass it, you just want to hook up some other light, correct? Shouldn't be a problem, just find which wires run to the stock light and wire in an aftermarket one. Something like this would work:
    Aluminum 12-Volt LED Indicator Light for flush mounting on a panel. Just hook up to any 12-volt power source, and you're ready to go.
    • DaveSmed
      • Apr 2007
      • 1406
      Stick with incandescent or make sure you put a resistor across the LED.
      The LED probably will not flow enough current for the alternator.
      -Dave
      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
      Need some help figuring out the ETM?
      • TG Goose
        • Jul 2011
        • 234
        Well, I'm actually removing the entire cluster minus the front display. I'd still like to have an alternator warning light, but I will be running a volt meter so its not a huge issue.
        I'd really like to know how to wire the alternator to bypass the cluster completely.
        Here is a preview of how the set up for the gauges. The rear cluster plastic will not be reinstalled (ie circuit board, SI board).
        1995 318ti - Sold
