e36 window switch help
  • rich4rdee
    • 595
    ugh..i got 4 sets of switches from the junkyard and none of em seem to work.
    i got 2 with white bases and 2 with green bases, and both seem to have the double click auto down feature.
    the white switch has part #1387388 and i'm assuming this is the "small base."
    the green switch has part #8365300.
    the problem is that when i connect the gray/red==green, and wire the 2 brown wires to the brown on the switch, the light comes on, but when i try the other 2 wires nothing happens.
    i've tried hooking the switches up to a 9v battery+test light and all lights come on, but when i click the buttons and probe the other 2 wires nothing happens.
    did i just waste $20?
  • rich4rdee
    • 595
    halp plz!
    • svn2002s
      • Sep 2004
      • 479
      did you follow the diy write up?
      • Balleristic31
        • Aug 2009
        • 4198
        If they are the one touch switches, then yes you did waste your money :/
        -NICK
        • rich4rdee
          • 595
          gahhh! i bought these at the junkyard after i had skimmed through the DIY. i remembered reading that the one touch feature wouldn't work without some sort of module, but figured that it'd function normally otherwise.
          • Blackout
            • Apr 2011
            • 4125
            None of the small base switches work without adding a control box. (Green, Blue, Black, White and Yellow)
            Only large WHITE OR BLUE base work in plug n play sense.
            » PARTS FOR SALE
            » TRANSACTION FEEDBACK
