Removing tweeters from tweeter pods?
  • funcrew
    • Jun 2007
    • 1223
    Yet another dumb question about an issue inherited from my idiot PO. My door tweeters are not wired up or functional, and the pods and/or doors have busted off tabs, thus the pods rattle around loose in the doors with a big gap. In order to anchor down the pods, I'd like to remove the weight of the actual tweeters. Is the tweeter separable from the pod? If so, how do you take them apart? Note that this is strictly cosmetic - I have no need for functional tweeters, just looking for rattle reduction and better appearance.
    Also, chewing gum failed, so I'm planning to use a tiny black sheetmetal screw to hold the pod to the door. If there's a better method, let me know.
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • StereoInstaller1
    GAS
    • 22679
    A strip o' the foam style double sided tape will do fine to keep it in place, assuming you clean everything.
    Closing SOON!
    Thanks for 10 years of fun!
    • MC Hammered
      • Jul 2008
      • 2076
      I used a flathead screwdriver and carefully popped it out.
      The 20 year old glue is quite brittle.
      My 1989 e30 s52 Touring... this is Betty
      My 1989 325i vert (sold)...this is Nina
      My 1991 M5 (sold)... this is Veronica
      Photo comparison: OEM vs aftermarket windscreen for a convertible
      • bmwman91
        • Oct 2004
        • 3128
        They are easy to remove. A screwdriver to pry with, and some needle-nosed pliers are all you need.
        Transaction Feedback: LINK
        • AE86
          • 272
          The other day, I removed tweeter pod being held up with some caulking, it worked really well.
          WTB: Diamond Schwartz Hood
          • AndrewBird
            The Mad Scientist
            • 11898
            Why not just buy a set of trim panels without tweeter pods? Hell, someone wanting tweeters might even trade you straight across.
            • jrobie79
              • Mar 2006
              • 2525
              Ill swap blanks for pods
              1991 318i ---- 308K - retired
              • funcrew
                • Jun 2007
                • 1223
                Done - Thanks for the tips. Now I get the premium sound look without the premium sound sharp-pointy-tweeter-pod-launching-into-my-vulnerable-lap-area-on-hard-left-handers excitement vibe.
                -Dr. Paul Forrester
