Car audio
  • misa1810
    • 1
    Car audio
    Car audio/video (car AV), auto radio, mobile audio, 12-volt and other terms are used to describe the sound or video system fitted in an automobile. While 12-volt audio and video systems are also used, marketed, or manufactured for marine, aviation, and buses, this article focuses on cars as the most common application. From the earliest days of radio, enthusiasts had adapted domestic equipment to use in their cars. In the 1960s, tape players using reel-to-reel equipment, Compact Cassettes, and then 8-track cartridges were introduced for in-car use. Cassette players were invented before 8-tracks, therefore put in cars before 8-tracks.
    A stock car audio system refers to the original equipment manufacturer (OEM) application that the vehicle's manufacturer specified to be installed when the car was built. The hi-fi systems of specialists such as Bang & Olufsen, Bose, and Harman International Industries (which encompasses brands such as Harman Kardon, JBL, and Mark Levinson) are available in several luxury car marques. A large after market industry exists where the consumer can at their desire replace many or all components of the stock system.
    In modern cars, the primary control device for an audio system is commonly referred to as a head unit, and is installed in the center of the dash panel between the driver and the passenger. In older vehicles that had audio components as an option, such devices were mounted externally to the top of or underneath the dash. Car speakers often use space-saving designs such as mounting a tweeter directly over a woofer or using non-circular cone shapes. Subwoofers are a specific type of loudspeaker for low frequency reproduction.
    Motorcycles have been utilized with similar equipment since they also have the so-called "car audio" experience. Even pedal bicycles, as well as homemade boomboxes have utilized sealed lead-acid batteries (or 12V power supplies) for applications outside of motor vehicle use, likewise the store displays which mount in demo models prior to aftermarket purchases for installation.
    photo mural
  • bernzpeed
    • 3917
    wtf
    89 E30 S52
    Transaction Feedback.
    • bastianshaw
      • Jan 2007
      • 2210
      seriously
      • harv
        • Nov 2004
        • 555
        For everyday body-washing: Get wet and pour several drops of soap full-strength onto hands-washcloth-loofah. Lather up, scrub down, rinse off, and tingle fresh and clean.
        For other uses: Dilute from one part soap into 40 parts water for light cleaning, to cutting it in half or using it full strength for heavy-duty grease-cutting jobs.
        For laundry: Use 1/4 cup to 1/3 cup for one regular load; adjust as needed depending on the hardness of your water. Adding a dash of baking soda makes it even better.
        My liquid soap turned cloudy. What happened, and what should I do to clear it up again?
        Our liquid soaps are so concentrated that they are nearly solid. Thus, when the temperature drops to about 50° F, the fatty acids begin to solidify and cloud out. Just put the soap in a warm room, or warm water, and it will clear up at about 70° F. But clear or cloudy, the soap works just the same.
        The Revolution will not be televised.
        • StereoInstaller1
          GAS
          • 22679
          I have the same thing very much and thank you
          Closing SOON!
          Thanks for 10 years of fun!
