I have a set of 6.5" speakers I want to use from my previous car. So I want to install them in the stock speaker holes but the magnets on these speakers are large and they won't fit using thin spacers. I can only think about enlarging the stock holes. So what's the best way to do it? Or any other suggestions? I don't want to buy a new set of 5.25" speakers if possible.
Best way to enlarge front speaker holes?
Tags: None
This depends on a couple of things.
First is magnet diameter. If you look in the holes, you will see the door jam area protrudes into the speaker area, so your diameter is the issue, depth not so much.
Second is the glovebox and hood release and how much you care about their functionality.
There is plenty of room in the doors though, as long as you check everything carefully.
GL!
LukeComment
Spacers need to be at least 1" thick. Therefore the speakers will likely interfere with the glovebox. And I want to avoid that. I may be able to do some trick on the hood release but not the glovebox. I planned to cut the kick panels to allow speakers to go through.
I'll double check the magnet size to see if it clears the door jamb first. Thanks for pointing this out, Luke. If I install them in the doors, I want them to be flush with the panels, not with the map pockets. Do you think that's possible? The mounting depth is 2.5".90 E30 S50B30
http://www.fquick.com/roadhazard/Comment
If you need 1" spacers, you likely won't have room...they must be huge.
I got some Polk 6.5" MOMO series midbass int he doors of a late model, they are like 2.75" D, but I used a 1/8" spacer under the door panel, was a very tight fit.Comment
Old school MB Quart Q series. The magnet itself isn't bad. It's the shape of the basket that causes the problem.
Do you have any pictures of the Polk in the doors? I'd like to see how you did it.90 E30 S50B30
Yeah, that basket is gonna cause you grief on the kicks.
BTW: I rarely take pics of stuff I only do once, but they are out there somewhere, the pics were not mine but they were shared a couple years ago.
Can I offer you a dirty dirty idea?
Put your glovebox on sliders and use a linear actuator to open and close it. Or, on the cheap, use a power antenna motor or a window motor...think how sexy that would be, using a stock power top switch...just remove the latch alltogether.Comment
Fuckin' A Scotty! What a grand god damn idea sir.Yeah, that basket is gonna cause you grief on the kicks.
Put your glovebox on sliders and use a linear actuator to open and close it. Or, on the cheap, use a power antenna motor or a window motor...think how sexy that would be, using a stock power top switch...just remove the latch alltogether.Different strokes for different folks.Comment
