relay
    relay
    So my fuel pump isn't getting power. neither is the fuse, So next is checking the relay right. Where is that located?
    All just means to an end.
    did you check your cps ?
      Start by checking power and signal at the main relay: it is the furthest forward of the 3 on the shock tower (m20 assumed).
      The main relay feeds the DME and the fuel pump relay
      Closing SOON!
      Thanks for 10 years of fun!
        nah its a m42..
          OK, so you have the same relay setup, but the group of 3 is under the wire covers
          Closing SOON!
