tried installing a radio
  • Bigal101
    • 30
    It was a complete failure
    got it to turn on and then the speakers don't work -___-
    bought new speakers,new stereo and the people who sold me the car
    did a fucked up job that when i turned on the car
    it burned out the ground cable completely; car started smoking disconnected the battery and followed them to the source cut them and
    now the powered windows are out!!
    any tips guys?
    Who can give me a hand fixing this?
    I live in LA :/
  • reelizmpro
    • 9558
    Did you replace a stock stereo? if so, you have to bypass the factory amp in the trunk or run your own speaker wires.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Bigal101
      • 30
      Barry, I did replace the stock radio because it wasn't working.
      I did pass new wiring but i used a piece of the old wiring that connected to the 2 back
      speakers.
      Where is the factory amp located?
      • reelizmpro
        • 9558
        in the trunk on the drivers side behind the panel. It's tucked away.
        88 M3 - LACHSSILBER
        • reelizmpro
          • 9558
          I'm sure there's a write up on it in the audio section.
          88 M3 - LACHSSILBER
          • Bigal101
            • 30
            Found the bypass write up
            ill check into it tomorrow
            so in order to get it working i need to put new wiring to the back
            speakers?
            In case I can't get this done
            would you be willing to give me a hand?
