Wire on C200 conector going SUPERHOT
  • mgromero
    • Aug 2011
    • 106
    Hi guys,
    the VIOLET wire in the conector C200 is getting super hot to touch whenever I turn on any of the 4 positions of the blower fan.
    If the blower fan is turned on in pos. 1 = wire getting hot at a slower pace
    if the blower fan is turned on in pos. 4= wire going thermonuclear quick.
    The strange part is that the wire is getting hot only in the ignition switch side of the connector. See picture for details. I can assume that the wire was changed or reparied in some point, because it have some tape.
    Any clue? this is driving me nuts and I dont want to go up in flames.
  • DaveSmed
    • Apr 2007
    • 1407
    Pull fuses 4, 5, 6, and 12. Does the blower motor still work?
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • toointoxicated60
      • Sep 2009
      • 355
      have you taken a look at whats under the tape? Poor connection would produce heat
      • Gregs///M
        • Mar 2012
        • 2459
        Yes, also be sure the wire gauge is the same or larger. A replace wire with smaller wire gauge will warm up like you see.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • mgromero
          • Aug 2011
          • 106
          Thanks for the tips I will check fuses and what is under the tape... maybe some funky connection.
          I will keep you guys posted.
          _M
          • mgromero
            • Aug 2011
            • 106
            More information,
            Removing fuses 4 5 or 6 the blower still works.
            Only removing the fuse 12 the blower turns off.
            Also with ONLY the fuse 12 in his place, and removing 4 5 and 6 the blower still work.
            Is this normal? Or I have a short somewhere?
            • DaveSmed
              • Apr 2007
              • 1407
              Fuse 12 is supposed to be a 7.5A fused circuit powering some small electronic things like your radio.
              Some chucklefuck somewhere along the line decided to wire your blower motor (which should be on fuse 20 FYI, a 30A rated circuit) to the wrong thing.
              At least you caught it before the fire.
              EDIT: Do NOT run the wipers and blower motor at the same time until it gets fixed!
              -Dave
              • mgromero
                • Aug 2011
                • 106
                oh shit
                Yes you are right, when I remove the fuse 12, the radio and clock and some other things go off.
                I guess I must remove the head to check out the wiring on the switch.
                In a "pain in the ass mixed with some pain in the groin" scale.. lets say 0 to 10...this jobs takes wich score?
                1? 10? 8412?
                • DaveSmed
                  • Apr 2007
                  • 1407
                  Removing the radio and taking a look back there isn't usually TOO bad. It is tight though. If you end up having to remove the center panel, there's a screw in a shitty spot that will prob keep ya busy for a bit.
                  -Dave
                  • mgromero
                    • Aug 2011
                    • 106
                    I also tested my current draw in the system
                    The meter set up to 10A.
                    With everything turned off = .21
                    with 1 light on (inside, trunk or glovebox) = .53
                    Is this a normal draw?
                    Dave, I will try to tackle the radio problem tomorrow taking a lot of picks, any help will be appretiated (:
                    • DaveSmed
                      • Apr 2007
                      • 1407
                      Those numbers should be more like 0.021 A.
                      Battery going dead if the car sits awhile?
                      -Dave
                      • mgromero
                        • Aug 2011
                        • 106
                        Yes actually I think that other chucklefuck installed a second battery in the front.
                        So I have 2 batteries, one in the trunk with the original wiring, and one in the front connected in series.
                        Removing the battery in the front , and measuring current draw from the back I get those readings.
                        If I should get a 0.020 reading setting up the meter to 10A .. that means that I still have a draw of 0.19 amps yet! Thats a lot.
                        I need to pull every damn fuse :P
