Will this work?
  • NotColtonOrr
    • Jun 2011
    • 243
    Will this work?
    I have an infinity reference 1062w DVC sub that I'm trying to run off of my MB Quart Onyx 4.60 amp.
    In order to do this I would need the amp at 4 ohms bridged by 2 channels. Is this right?
    And if so, how would it be wired? I've tried it a few different ways that I thought were correct but kept getting no sound.
    The rest of my speakers are working fine (4 premium sound speakers running off another onyx 4.60 amp.)
  • Gregs///M
    • Mar 2012
    • 2459
    You want to bridge both pairs of channels so that you have two outputs. Then hook each bridged channel to each voice coil. You want to me sure your amp inputs are truly mono and not stereo input or your voicecoils will be getting different signals. You want your voice coils to have the same exact signal. You can use a RCA y adapter or if your amp has a mono signal input selector you can use that.
    The amp manual should have recommend wiring diagram. Read it.
    + on 1st bridged channel to + on 1st voice coil. (-) from 1st bridged channel to (-) on 1st voice coil. Repeat with other bridged channel.
    If you have no audio still, could be the amp is not turning on, no signal to amp, or woofer is bad.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
