driving without the cluster
  • kman_e30
    • May 2007
    • 573
    will driving the car with out the cluster damage anything? i talked to two different experienced e30 guys, one says it will cause electrical issues, the other says he has driven his car with out a cluster many times and never had any problems. im asking because i after getting my cage installed i didnt want to put the dash board back in, so im going to make a plate to house some after market gauges, and im sick of having my cluster taped down in my car.
    84 318i drift car
    04 mk4 gti 1.8t
    96 e320
    63 plymouth valiant
  • Gregs///M
    • Mar 2012
    • 2459
    The charging circuit from the alternator to the battery runs through the cluster. So removing the cluster, without "jumping" the input and output charge wires will make your car die once the battery charge is depleted. Without the cluster in place, the battery will not charge and it will die within 15 minutes.
    You will need to find which wire is the incoming charge and which is the output charge and jumper them together. I'm not sure which wires they are because I've never had to drive an e30 without the cluster.
    You can find this information in the Electronics troubleshooting manual located on this site.
    Please share your findings with the rest of the community when you are done. Thanks
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • homegrone30
      • Jun 2007
      • 1449
      Originally posted by Gregs///M
      The charging circuit from the alternator to the battery runs through the cluster. So removing the cluster, without "jumping" the input and output charge wires will make your car die once the battery charge is depleted. Without the cluster in place, the battery will not charge and it will die within 15 minutes Thanks
      Try two weeks. I believe it was a green wire. I went through this installing new tach. If I pull my dash off anytime soon Ill snap some pics. Op pm me if you need some help. P.s. if you wire it like i did you will need a diode or your car will not turn off.
      • homegrone30
        • Jun 2007
        • 1449
        Picture of said tach for the ney sayers.
        • James Crivellone
          Head Janitor
          • 6301
          why not just fix the factory instrumentation?
          • homegrone30
            • Jun 2007
            • 1449
            In my situation it was cheaper easier and I needed more rpms for my i swap.
            • Click
              • 637
              I can personally vouch that the battery will not last a half hour of drive time without the cluster in.
              ส็็็็็็็็็็็็็็็็็็็็็็็็็
              I need you to exfoliate my ballsack
              Build Thread?
              • homegrone30
                • Jun 2007
                • 1449
                It will when you replace your battery and alternator with your motor before you install a tach. I dont drive far to work. But im totally cereal two weeks.
                • e30Hungry
                  • 250
                  I had my cluster out for 2 weeks and my battery didn't die.
                  1987 - 325e Project / DD
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    interesting
                    • FLG
                      • Sep 2011
                      • 3165
                      If your idling for 15 minutes and your battery dies, than either it wasnt charged to start with or its junk.
                      With daytime driving and minimal electrical usage, id say you can make a couple of hours of drive time.
                      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                      • Ryann
                        • 3350
                        You'll have to make a jumper that goes between the all green wire and all blue wire in the cluster connector behind the temp. gauge in order to excite your regulator. If your car's an auto then you may or may not have issues with the speed sensor signal to the DME, idk.
                        • Gregs///M
                          • Mar 2012
                          • 2459
                          I have a brand new car battery and a good alternator. My car lasted just under 30 minutes without dying. But eventually it will die.
                          I do not believe a car battery can last 2 weeks without a single charge if your driving it everyday.
                          www.BavRest.com
                          My Feedback Thread
                          Our Facebook!
                          • firstRWD
                            • 73
                            I had my cluster out for a few days while I was trying to diagnose a temp issue(turned out to be the gauge). I can't say I remember exactly how much I drove it, but it never died. Maybe it was one start away from dead, maybe 50, I don't know, but it didn't have any problems for those few days.
                            • kman_e30
                              • May 2007
                              • 573
                              awesome, ill try that. i havent been able to work on the car in like a week lol, but im trying to get it ready for bimmerfest this weekend. i might put the dash back in, but i want to build a custom cluster for it.
                              84 318i drift car
                              04 mk4 gti 1.8t
                              96 e320
                              63 plymouth valiant
