Keep power to windows after car is turned off
  • kumulonimbus
    • May 2012
    • 178
    I often turn off my engine and then realize that all my windows and sunroof are open. On my parent's minivan the windows keep working for a short time after the car is turned off.
    Anybody know how this might be possible with a bit of rewiring? The timer isn't totally necessary. The cigarette lighter keeps its power after the car is off, and I would rather it shut off, so would it be possible to in a sense reverse the power behaviour of the cigarette lighter and window switches?
    1990 BMW 325i Coupe
  • AndrewBird
    The Mad Scientist
    • 11898
    This should do it:
    http://www.the12volt.com/relays/relaydiagram30.html
    Just instead of hooking your radio to it, hook the power windows to it. Then the windows will work until you open the door.
    • Tino-m30b35
      • Feb 2011
      • 56
      With the ignition off, when you open one of the doors, my car's windows will work.
      92 Opel Monza CLi 200i8v Exec
      92 Opel Rekord 380GSiV6
      87 BMW E30 335i (M30B35)
      91 BMW E34 520i (M50B20) with Mtech Turbines
      95 Hyundai Elantra with Mitsu 4G63
      Three Aircooled VW Beetles
      17.8Litres, 38cylinders, 10Cams and 84valves
      • buffalino
        • Jun 2010
        • 61
        mine do the same,,, try with the door open
        • Charley
          • 396
          What those guy's said ^^^
          • Gregs///M
            • Mar 2012
            • 2459
            Windows are high current devices. Be sure to use wire that is of equal or greater than the cross section diameter conductor of the original wires. 12AWG wire would be safe to use for custom window power wiring.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • kumulonimbus
              • May 2012
              • 178
              Is this standard in all power window-equipped E30s? My car doesn't seem to do this. Here's what I did:
              • With car engine running, turn off car
              • Open door
              • Press window switch (doesn't work)
              Thanks for the advice, I will definitely keep this in mind.
              1990 BMW 325i Coupe
              • MoreMayhem
                • Feb 2012
                • 650
                Maybe this is on non-US cars only, judging by the three who said it works for them?
                Would be nice though, as all my other cars have retained accessory power for windows and radio.
                • Kvasi
                  • Apr 2011
                  • 1122
                  My windows and sunroof also works with a door open and ign off.
                  • jrobie79
                    • Mar 2006
                    • 2525
                    as soon as I turn the car off, I have no power to anything. Same situation as the OP...
                    1991 318i ---- 308K - retired
                    • kumulonimbus
                      • May 2012
                      • 178
                      You may be right, could be a non-US thing. Why does the US do this to us?
                      I wonder how the non-US ones are wired that makes the windows/sunroof behave in this way. Seems like it would be the "right" way to do this mod for US cars
                      1990 BMW 325i Coupe
                      • smyleboyd
                        • Sep 2011
                        • 1164
                        my car does this too! its a 1991 U.S. 318i so idk if its a euro car thing. i noticed one day my windows didnt work and after some thinking and research i found that it was the ground from my starter so i electrical taped it. my windows worked how they should for acouple days. then i noticed that the fan and window light on the switches stayed on after i turned off the car and took the keys out of the ignition. Should i replace the ground? Or is it a different problem? Any input is appreciated!!
