Aftermarket radio only on when lights are on
    Easy answer grounded to light ground not the case here
    I have grounded the radio to the car and still the radio only turns on with the lights. I have traced the 12v and ignition wires to there correct locations
    The car has no other electrical issues
    Btw it's a 1987 with a premium factory system. The car came with no radio
    325i
    325i
    im no expert but it sounds like you are using the 'illum' wire to feed the unit.
    that illum is the illumination when the lights are on.
    (+12V Unswitched) Yellow----Red/Green (Changes to Yellow at C302)
    (+12V ACC) Red-------------Violet/White (Changes to Voilet/Grey at C302)
    (Ground) Black---------------Brown (may also be Brown/Black)
    (ILL) Orange-----------------Grey/Red (Changes to White at C302)
    (P ANT) Blue-----------------White (this is one of 2 white wires)
    (AMP REM) Blue/White--------White (this is the one in the same harness as the speakers)
    Luke
    Originally posted by der affe
    What are you going to start a thread about next? "My woman's skinny jeans chaffe my special parts, f*ck skin irritation"
    Originally posted by navid41691
    And no, I use lotion so I don't have to worry about skin irritation.
    '...rolling balls, i'm elated, i'm going dumb now; drinking liquor i'm faded and having fun now; loaded gun and tripping with everyone around; keep me stuck in the sky, i never wanna come down...'...kabosh
      Nope using the green red ignition wire and red 12 v. After 100 installs of radios over my life this is a first
        Measure your accessory and constant power wires with a meter, DC scale. Turn the illumination on and off to see which wire switches "states." Constant should be constant 12 volts of course. Accessory should turn on with 1 notch turn of the key.
        Measure your ground with continuity to chassis ground. Does its electrical state change when illumination is turned on?
        With over 100 radio installs, you should know these basic troubleshooting techniques.
        Worse comes to worse, your radio harness might have been tampered with. Grab new radio wires at the ignition harness.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
          So I swapped in a whole new radio harness and same thing. Took this too my e30 BMW master tech, worked at BMW Seattle for 31 years. We are both stumped. At this point I wired the ignition wire to the cigarette lighter. Hopefully there wont be a big draw.
