My interior lights kind of flicker with the car running. They go dim then bright, then dim then bright, etc. Car has a brand new alternator and the battery should be good also. They do this constantly and not associated with rpms. Possible issues?
interior lights flicker
Electrical issue for sure. I would check the interior lights grounds. They are probably located above the brake pedal alongside the cluster grounds. Check the ETM manual to locate all interior lights grounds. Clean those grounds with wire brush.
Also check your engine ground cable from your oil pan to frame rail. This cable carries ground from the engine (and alternator) back to the battery. Be sure it is in good condition, not corroded or greasy. Clean those connections too. If you need replacements, send me a PM or check out my thread on engine grounds.
Did this problem occur with the old alternator?Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
It should be from anywhere the engine block is bolted to or "has electrical continuity" with the engine block to the frame rail.Owner - Bavarian Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
I just took a look at the ETM for my 1989 and there are two grounds in the window circuit.
G200 above the brake pedal.
G300 behind left LH side of rear seat.
I would clean both connections points.Owner - Bavarian Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
