Antenna Wiring
  • hotballs
    • 1155
    Antenna Wiring
    I'm looking for some electrical help.
    Here's the problem. I got a used electric antenna for my e28 only the circuit board has been removed and someone has directly wired the white and red plug directly to the positive and negative of the electric motor.
    The way the antennas normally work is that there is 12V hot at all times running from the red wire and 12V when the radio is in the ON position running to the white white wire. There is a black wire for ground.
    The antenna I have is simply two leads running to the electric motor. Put power to red and ground white, motor makes the antenna go up. Reverse the leads, put power to white and ground to red the antenna goes back down.
    My question is, how can I wire up something which uses the factory connector and goes UP with the radio turned ON and goes back DOWN with the radio is turned OFF. This is the original intention of the antenna and what the circuit board that is no longer there did.
    Here's a picture of my old antenna with a fried circuit board and the used one without the circuit board.
    Using relays or something how can I wire something up so it goes up with the radio on and down with the radio off? Is it possible? I don't want to run an extra switch.
  • jeffnhiscars
    • Jun 2011
    • 6010
    I believe the circuit board tells the motor when to stop at full up or down so I'm not sure it can be bypassed. Used ones are around for a reasonable price.
    Alice the Time Capsule
    • hotballs
      • 1155
      Yes, in my post I say that I want to replicate what the circuit board does with relays and switches and make it do what it's supposed to do etc. I'm tired of buying used junk that doesn't work, people say they tested it and it works etc, and then you get it and the mast is all bent or it's been rewired as above. Just trying to make what I have work.
      • StereoInstaller1
        GAS
        • 22679
        You cannot duplicate the stock functions without some form of controller...give up now, don't waste your time. Or, let me ask you this: do you really think that circuit board can be replicated by a pile of relays and shit? Did BMW waste a whole bunch of time making that board?
        Is it really that hard to find an antenna? I bet there are 10 of them here, if not more.
        GL!
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • hotballs
          • 1155
          Thanks Luke, I was looking for you when I posted that. I thought MAYBE there might be a sequence of relays and switches that would allow it to do the same thing. I found something online, but I didn't really understand the terminology.
          So you're telling me you don't build circuit boards? :)
          • StereoInstaller1
            GAS
            • 22679
            Dammit Jim, I'm an installer not a doctor!
            Closing SOON!
