Central Locking on a Convertible
  • caffeinatedsoap
    • 360
    Sometimes I park my car with the top down. I then lock the car to secure the trunk. The issue is that if someone reaches inside and opens the handle from the inside all the locks unlock. Now this makes sense with the top up and you want to get out of a locked car but with the top down its kind of a pain in the ass. What do you guys do?
    1992 318ic
  • reelizmpro
    • 9534
    Use the deadbolt feature if u must park with the top down.
    There's also alarms with radar sensors and two way alerts.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • idanity
      • Jun 2006
      • 775
      i use a proximity sensor for my alarm...it will warn chirp if you walk by it, and go into panic mode if it see anything (hands, birds, cats) getting into the cabin area...
      that, and btw, no-ones car is safe from breaking a window...or cutting the top.
      3 pedal club
      200,k+ club
      cabrio club
      port-matched- polished- purring www.BMWpark.org
      </div>
      linux since 1999
      • caffeinatedsoap
        • 360
        What's the deadbolt feature?
        1992 318ic
        • idanity
          • Jun 2006
          • 775
          deadbolting is turning the trunk lock to the vertical position, and inso doing, all doors will not able to be opened using the interior handles (as with all cabrios)
          3 pedal club
          200,k+ club
          cabrio club
          </div>
          linux since 1999
          • RAYREY
            • 212
            my major tip of the day
            Thanks Idanity your deadbolt feature tip rocks!:)
            1991 325i coupe
            1992 318i conv
            2002 540i sedan
            What did the e30 owner say to the other e30 owner? LOOKING GOOD!
            • fporro
              • 1859
              I'll second that.
              thought all e30's had that particular function.
              • P.Kelly
                • Aug 2011
                • 367
                It is called "double lock" and you turn the driver's side door lock right 90 degrees from the vertical to the horizontal position and pull the key out.
                The Definitive 1991 M-Technic Thread - a work in progress
                • reelizmpro
                  • 9534
                  This is how I understood it to work. Not sure if it can be done any other way.
                  88 M3 - LACHSSILBER
