Stock Wiring Gauge Size
  • bmwstephen
    • 2463
    Picking up a set of butt connectors because I am motivated to redo a clean wiring job on my car. Typical areas I'm focusing on are Stereo and Alarm. Can someone verify the size gauging of these wires including: 12+, Ignition, Ground, Parking lights, Speaker wires?
    I assume I should just stick with red butt connectors 18-24. I noticed my wires to my windows are the really thick ones that require Blue 14-16 in size.
  • devon.818
    • Feb 2011
    • 2937
    clean wiring job and butt connectors is an oxymoron sir.
    solder+shrink wrap
    • bmwstephen
      • 2463
      don't tell luke that =p
      • bmwstephen
        • 2463
        bump
        • Gregs///M
          • Mar 2012
          • 2459
          Originally posted by travish325
          Wow, you are a big help to this forum. (not srs) Hope you get banned.
          If you are going to use butt connectors, I would buy the assortment of pink/red, blue, and yellow.
          Chances are you won't use the yellows except the ignition switch wires but i would try blue on those before yellow.
          I prefer solder and heat shrink because an open crimped connector will oxidize over time and cause increased resistance, thus a poor connection. However, some people in this forum disagree with me on that topic. There was a huge debate over crimp vs solder so you can check that out if your are interested.
          Owner - Bavarian Restoration
          BMW and European Electronics Repair and Restoration
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
          Follow our Instagram!
          • bmwstephen
            • 2463
            i hear ya. regardless its still a good idea for me to know the gauge size of the wires. I need to lengthen some wires because this car has been through a lot of alarms and stereos the point the harness cannot get any shorter
            • Gregs///M
              • Mar 2012
              • 2459
              The ETM manual has every wire gauge and color. Its the first number before the wire color but it is in metric. There is a conversion chart in the "how to use this manual" section.
              Ignition wires are 12 gauge for sure. The speakers are 18 gauge I think. I would check the ETM for the particular wire you want to extend just to be sure.
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
