Stereo guys i need your halp!
  • StealthiE30
    • Jun 2012
    • 491
    Ok so i decided it was time for an upgrade on my stockish stereo system.
    So yesterday i finally had time to put in a panasonic head unit i had,
    along with a 12inch infinty sub and some no name 1200 watt mono amp.
    Well i got everything wired up per some of the diagrams i found on here
    and nothing! No power to the head unit, no power to the amp, nothing!
    The stereo was working before i did this, the only issue was i had to input my
    stereo code and adjust my settings every time i turned the car on.
    Its an 85 eta that had the front two speakers replaced by the PO.
    Will post pics if needed, and any help is much appreciated.
    IcWhatUdidThere
  • AndrewBird
    The Mad Scientist
    • 11892
    Did you check for blown fuses?
    • StealthiE30
      • Jun 2012
      • 491
      Yes I did, there are a few that control the radio correct?
      IcWhatUdidThere
      • StealthiE30
        • Jun 2012
        • 491
        Originally posted by John1
        Dear first you have to plug all the jacks and then try it. May be there are some wiring problem. have you checked it by any meter? I don't there should be any problem in you stereo head. Can you took some pictures of your wired work and upload them on you post. Then you can get the right and clear guidance form forum. Without them we can only told you the ideas which we guess from your post.
        My wire work is shit lol, but it is done per diagrams i have found online. I will try to upload some pics after work today. And by jacks do you mean Rca inputs?
        IcWhatUdidThere
        • AndrewBird
          The Mad Scientist
          • 11892
          Double check your connections at the HU. You must have wiring something wrong.
          • Gregs///M
            • Mar 2012
            • 2459
            Without the radio turning on, the amp will not turn on. First troubleshoot the radio.
            There should be constant 12 volts on the yellow wire.
            Switched 12V on the red wire (key switched)
            and ground on the black wire, it should go to a brown wire or chassis ground.
            Should be simple to verify those three wires.
            Remote turn on for the amp should be connected to the OEM white wire or the blue/white wire from the head unit. This triggers the amp to turn on.
            Be sure you installed a fuse on the main battery connection for the sub amp.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • Thizzelle
              • 4422
              use lukes wire up thread in sticky threads and get back to us. something isn't hooked up right. And if your not getting 12v from the wires then trace that wire to find the problem. Simple but time consuming
              "I wanna see da boat movie"
              "I got a tree on my house"
              • StealthiE30
                • Jun 2012
                • 491
                Thanks for the input, im quite sure ive got those all hooked up right. Heres a few pics dont mind the tape, ill be crimping them up once i have it all figured out.
                I had these switched around in the pic to see if that was the right way...
                The only real confusing wires were all the speaker wires... as i had more wires then actual speakers...
                And heres a pic of the fuse and ground out back...
                IcWhatUdidThere
                • StealthiE30
                  • Jun 2012
                  • 491
                  And fuse 12,17, and 27 were all good in the fusebox.
                  IcWhatUdidThere
                  • future rs
                    • Aug 2012
                    • 514
                    Do you have a multi meter?
                    • StealthiE30
                      • Jun 2012
                      • 491
                      I do not, i was going to borrow my friends but forgot to grab it before he took off..
                      IcWhatUdidThere
                      • AndrewBird
                        The Mad Scientist
                        • 11892
                        You don't need a multimeter, you need a test light. Buy one (they are only a few bucks) and check for power and switched power at the dash. Also, did you read Luke's sticky? You should be able to unwrap the harness and find twisted pairs of speaker wires. Remember, there are two wires for every speaker, meaning there should be 8 wires.
                        • StealthiE30
                          • Jun 2012
                          • 491
                          Ok ill get a test light, would not having all the speaker wires hooked up prevent everything from turning on?
                          IcWhatUdidThere
                          • dwvw
                            • Sep 2011
                            • 234
                            No, it should turn on without any speakers connected. I am not a big fan of test lights. You probably won't damage anything in an E30 with one, but don't use it on any unknown wiring on anything more modern. Buy a multimeter, they are cheap nowadays and will give you much better info than a test light.
                            • Gregs///M
                              • Mar 2012
                              • 2459
                              The wire on your yellow is grey/red. This is the illumination power wire and will not work.
                              You need to find the constant power source wire. Red/green wire or red/yellow wire. I think I can see red/yellow in the pic.
                              www.BavRest.com
                              My Feedback Thread
                              Our Facebook!
