Electrical Issues
  • johannmaximus
    • May 2012
    • 22
    Electrical Issues
    I'm having a few issues with my '89 325iX. The biggest issue, and the biggest headscratcher involves the blower fan. Every time I turn it on, the fan works perfectly, but the fuse itself will burn up. It won't blow, just smoke and burn up. I think a PO had the same problem, because the fuse box is modified with thicker wiring and a 30 amp fuse at fuse 20.
    Problem two is the tachometer, fuel economy gauge, and the OBC. All of a sudden, all of them just stopped working. The fuse is fine, but I do think there is a short somewhere. If anybody has had this problem, and knows how to solve it, I would be very appreciative.
    Selling parts here: http://www.r3vlimited.com/board/showthread.php?t=252285
  • Gregs///M
    • Mar 2012
    • 2459
    First problem,
    You heater blower motor is probably shot and pulling more current than it should. Since your PO installed new wiring of thicker gauge, it is a sure sign of a band aid fix. I would say your car is at risk of fire until it is replaced or fused removed and you do not power it anymore. I suggest you buy a new one or good used one and swap it in. If your problems continue, you can suspect a short in the wiring. HOwever, a short in the wiring usually blows the fuse right away.
    Problem two,
    These are all classic signs of a failed SI board. Once the batteries on the board die, all of these gauges fail to operator intermittently. You can replace the batteries yourself or purchase a refurbished SI board from me. You can check my "services" section in my signature for more info on this.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • johannmaximus
      • May 2012
      • 22
      Originally posted by Gregs///M
      First problem,
      Problem two,
      Problem 1: That's what I was worried about. Other sources say that the blower motor wouldn't work on all its settings if it was drawing too much current. I don't know though, so I'll plug in a new fan, and try to put in a new fusebox.
      Problem 2: I looked into it more, and it turned out the fuse had blown. If the SI board fails, does the speedo fail as well?
      • Gregs///M
        • Mar 2012
        • 2459
        #1, this is not true. The fan can pull its over current at max setting. It can definitely still operate at full speed, yet pull more current than rated. I recommend you disconnect the blower, at the connector local to it. Then test all your circuits with new fuses. If no fuses blow, the blower itself needs replacing.
        #2. When the SI board batteries die, the speedo will continue to operate.
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        • StereoInstaller1
          GAS
          • 22679
          Greg is 100% spot on.
          Pull the fan cover and spin the thing, that should tell you quickly about the fan
          Closing SOON!
          Thanks for 10 years of fun!
          • johannmaximus
            • May 2012
            • 22
            What is the fan supposed to do when you spin it?
            • AndrewBird
              The Mad Scientist
              • 11898
              It should spin freely and for several seconds. Basically the bearings in them wear out, get sticky/rough and therefore the motor has to try harder to turn, drawing more current.
