Flickering headlights.
  • e30e
    • Dec 2004
    • 2176
    When my subs are hitting hard my headlights are flickering almost giving my lights an appearance of flashing. I turned down the bass at both the amp and head unit. The setup is a pioneer head unit, two 10 inch mtx subs, and of course I can't see my amp right now to get specs.
    What's my next step for looking at stuff or what parts am I needing.
    1985 BMW 325e
    1997 BMW M3/4/5
    2007 Chevy Silverado Crew Cab 5.3 v8
  • Schnitzer318is
    • Jan 2008
    • 2057
    You need a larger alternator... good luck. Or switch to HID headlights in US Projectors or smileys.
    "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
    91 318is Turbo Sold
    87 325 Daily driver Sold
    06 4.8is X5
    06 Mtec X3
    05 4.4i X5 Sold
    92 325ic Sold & Re-purchased
    90 325i Sold
    97 328is Sold
    01 323ci Sold
    92 325i Sold
    83 528e Totaled
    98 328i Sold
    93 325i Sold
    • DRTSRFR
      • May 2008
      • 1836
      Where are you getting amp power?
      Where is it grounded?
      Suspension tips here...
      http://www.r3vlimited.com/board/album.php?albumid=757
      • Gregs///M
        • Mar 2012
        • 2459
        This is very common. Here are a few tips to reduce or eliminate besides upgrading to HID as Schnitzer recommended (I do too.)
        1. Clean and re-secure the grounds for the headlights. These are located in the engine bay near the wheel wells. Remove the ring lugs, clean with wire brush. Clean contact points. Secure tightly. All ground wires in BMW is solid brown.
        2. Clean ground lugs from headlight/dimmer switch. I believe these are located under the steering column above the brake pedal. Do the same process as #1. There is a metal bracket above the brake pedal, it has two 10mm nuts. Clean those connections, which are shared with the cluster and windows. You might find your windows travel up faster.
        3. I sell these alternator and ground cable upgrade kits. OEM is 8AWG equivalent and the upgrades are 2AWG. They handle much more current than the OEM. Once cable runs from the alternator to the starter and one is a replacement engine ground. The alternator cable alone would help since it will allow a greater current flow to the battery and thus to the amp.
        4. Install a power capacitor in parallel with the bass amp. This should supply the amp with the current capacity that it needs.
        5. Install a high output alternator or extra car battery.
        GL
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • Mouse
          • 377
          GL
          You definitely need to upgrade to take care of this problem, but this simple tip yields surprising results. Especially on our older..err experienced vehicles.
          1982 528e - Sold
          1987 325e - Totalled
          1990 325is - Sold
          1997 540i6 - Sold
          1991 325ic - Sold
          2013 335i - Sold
          2005 X5 - Daily
          1991 318is - *work in progress*
