radio problem
  • lwde30
    • 73
    radio problem
    ok first i have been searching for week on here and different forums but can not find a answer i need.
    so i recently urchased a e30 and imbuilding it up. and right now im on the audio part orf it. but previous owner had radio stolen and all the wire wher yacked out. i tool apart the center dash since it was broken. i have ill put together but when i go to seperate the wires for the radio i can only locate the speaker wire and antena. there is no power or ground conection i can not find it.there are no ripsed wires or nothing its like there gone.
    solutions:
    1] get new radio harness
    or
    2] run new radio power and ground cables. only problem i dont know where to run the wire to. if i go straight to the battery the radio will never turn off
    please help and trust i have been seaching
  • bmw325csi
    • May 2007
    • 4045
    Run the power wire from an ignition source, ground it up to any brown wire or the chassis.
    Do you have a premium sound system? (with amp)
    harry/harout
    • lwde30
      • 73
      stock premium sound system no
      i wil be upgraing to a 2 am systemo i will use rca for sound
      • lwde30
        • 73
        also what the best source to tab into. whre can i find it
        • bmw325csi
          • May 2007
          • 4045
          not sure on the colors however I would suggest using a test light and locating a power source that only works with your ignition on.
          You also need to run a single wire to your amps to turn them on with the head unit. The same ignition wire should be fine just put an in line fuse near the amp.
          harry/harout
