Help me figure out wiring to re-install my stock radio
  • noid
    • 1537
    So luckily my E30 came with the original radio in the trunk. The aftermarket radio currently installed is a POS and after looking at the wiring I am nearly certain that it was installed incorrect.
    From the car:
    Brown Black wire - directly connected to the after market radio harness
    Yellow - dangling not connected to anything
    Blue - Dangling not connected to anything
    Yellow red - aftermarket harness is spliced into this wire not directly connected
    Yellow (currently do not remember if the same yellow as above could have been striped)- aftermarket harness is spliced into this wire not directly connected
    Blue red - aftermarket harness is spliced into this wire not directly connected
    Black blue - aftermarket harness is spliced into this wire not directly connected
    White wire from the car is spliced into purple/grey power wire from the car and then the purple/grey is spliced into the aftermarket harness.
    2 pin plug
    Grey with red
    Red with tiny grey line - spliced into aftermarket radio harness
    From my stock radio:
    Purple Grey
    Black Brown
    White
    Blue
    Yellow
    2 pin plug:
    yellow
    white
    The steps I plan to do:
    1. Unsplice everything that is spliced
    2. Purple Grey, black grey, white, blue and yellow are accounted for so I will connect those back together
    Question 1: Is this plug stock? There is one white wire that goes nowhere, and one wire that goes somewhere into the back. Both seem to me to be two thick to be stock wires. Then on the other end of the plug are two white wires from the car that do seem to be the right thickness to be stock radio wiring:
    On top of this plug I also have this plug where I mentioned above wherein the white wire from the car splices into the purple/grey from the car and then that goes into the aftermarket wiring harness.
    So that leaves me with 3 white wires coming from the car, yet only one white wire from my radio. What should I do with this mess?
    Question 2: Am I missing anything from my stock wiring to sucessfully re-install my original radio?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • noid
    • 1537
    All figured out.
    • e30e28ny
      • Dec 2013
      • 4
      Where did the white wire in the pic second from bottom connect to?
      • StereoInstaller1
        GAS
        • 22679
        on the back of the deck is a little jack. Some models it can be hard to spot, depends on which radio.
        Closing SOON!
        Thanks for 10 years of fun!
