Antenna wire cut, any help?
  • Sputnik
    • Jan 2010
    • 808
    The antenna wire was cut near the antenna base due to the previous owner's ill-thinking, is there a way I can splice the two back together or am I going to have to run a new wire from thre reciever to the antenna?
    Bless me with your knowledge
  • bmw325csi
    • May 2007
    • 4045
    You can carefully do it. Gently strip the wire, there should be a wire shield on the outside with a single strand inside. Connect the single strand together and connect the outer shield together. Make sure they don't come in contact with each other
    harry/harout
    • bmwstephen
      • 2463
      you're going to have to run a new wire. remove radio, knee bolster under the dash, driver side kick panel, speaker, door trim covering carpet, rear seats.
      you should be able to find a replacement in the junkyard
      • Sputnik
        • Jan 2010
        • 808
        Question is how do I connect the two together?
        • bmw325csi
          • May 2007
          • 4045
          Which two. I used some butt connectors and electrical tape to keep the separated
          harry/harout
          • bmwstephen
            • 2463
            that single strand is as thin as a strand of hair no? how would you connect it
            • bmw325csi
              • May 2007
              • 4045
              Very doable. Just twist them a bit and put a "jelly bean" and crimp it
              harry/harout
              • Sputnik
                • Jan 2010
                • 808
                Sounds good, I'll give it a go tomorrow. Thanks broski
                • bmw325csi
                  • May 2007
                  • 4045
                  You got it brohana montana
                  harry/harout
                  • AndrewBird
                    The Mad Scientist
                    • 11892
                    If you had to, you could put a male and female connector on each end and just plug them together.
