OBD2 Scan and check engine light
  • bigdrick323
    • Feb 2012
    • 616
    Tried to do a obd2 scan but it is not connecting. Power light comes on but not connecting to one of the sides, computer or car, not sure. Any thoughts?
    sigpicMy Project!
    Official North Texas Bimmers Club E30 Representative
    www.BimmerAlliance.net
    "If you have questions about events or need help in the DFW area don't be afraid to contact me."
  • StereoInstaller1
    GAS
    • 22679
    On your OBD1 E30?
    Closing SOON!
    Thanks for 10 years of fun!
    • bigdrick323
      • Feb 2012
      • 616
      On your OBD1 E30?
      Will obd2 scanner not work on this car, sets up the same as my e46....
      Sent from my HTC One V using Tapatalk 2
      sigpicMy Project!
      • StereoInstaller1
        GAS
        • 22679
        E46 = OBDII, so has 2 way communication. OBD1, AFAIK, lacks that ability, only a somewhat readable datastream.
        Closing SOON!
          • 34839
          it's not going to work.
          you want to do a "stomp test". E30s are basically at the technology level of sending an SOS signal through a series of beeps, only it uses the CEL to signal it's primitave morse code for "my engine is fucked" instead.
          • bigdrick323
            • Feb 2012
            • 616
            Someone I'm sure has better idea about how to read them, it has a port for reading. What do I need?
            sigpicMy Project!
              • 34839
              you're expecting it to give you OBDII levels of information but the stomp test gives you everything it has. It's not going to do what you think it does, it's way more primitive than that. it really is just a series of flashes from the CEL. # of flashes = specific code.
              do a search for BMW stomp test. the only caveat is your TPS must function correctly.
              • bigdrick323
                • Feb 2012
                • 616
                Thank you, I'll check into it!
                sigpicMy Project!
                • StereoInstaller1
                  GAS
                  • 22679
                  It has a port, yes. For reading, not so much.
                  Closing SOON!
                  • bigdrick323
                    • Feb 2012
                    • 616
                    hahaha :)
                    sigpicMy Project!
                    • bigdrick323
                      • Feb 2012
                      • 616
                      Stomp test didn't work, as soon as I turned car on check engine light is flashing and the 5 pedal thrusts and releases doesn't change anything with the check engine light.
                      sigpicMy Project!
                      • StereoInstaller1
                        GAS
                        • 22679
                        What year/model? Stomp test does not work until motronic 1.3, so roughly 3/89 or later.
                        Closing SOON!
                        • bigdrick323
                          • Feb 2012
                          • 616
                          http://www.unofficialbmw.com/repair_faqs/motronic.html
                          It's an '88 325ic. vin: WBABB1300J1930560
                          sigpicMy Project!
                          • StereoInstaller1
                            GAS
                            • 22679
                            eh, was that unofficial page of any use? I know you can swap a "173" DME, that is what I did, but I never got the stomp test to work on mine, even after all was verified to be working. My ex's 7/89 325i worked flawlessly, but even swapping DMEs with her car I got no stomp test.
                            I even metered the pins on the DME, that TPS switch was correct values and all.
                            Closing SOON!
                            • UNHCLL
                              • 8790
                              Below the radar...
