Passive and Active Crossovers, EQ's etc...
  • kylebes1
    • May 2004
    • 2804
    Who has them and which ones do you like the most.
  • StereoInstaller1
    GAS
    • 22679
    Fuckabunchof passive crossovers.
    Audiocontrol FTW!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • marakka
      Euro Parts Pimp
      • Apr 2005
      • 2036
      Thats what I was gonna say ^^^^^
      Audiocontrol will never let you down.
      • kylebes1
        • May 2004
        • 2804
        Well that is what I have already.
        EQS with a 4XS to seperate mids and tweeter signal. I have to get another AMP though. Actually two more.
        I suppose I will end up with two four channel amps- 4 tweeters and 4 midbass and 1 mono amp for the sealed cabin sub.
        I may end up with another amp and add a rear facing ported sub... since the sound of a sealed sub and a ported sub are so different.
        -Kyle
        • marakka
          Euro Parts Pimp
          • Apr 2005
          • 2036
          Do you have 2 separate mid sets and 2 separate tweeter sets or do you have 2 component sets?
          • StereoInstaller1
            GAS
            • 22679
            -Kyle
            Kyle, since you are using a EQs, you don't have a fader or sub control?
            Go to 6XS, you get a sub level knob for your dash, front is tri-amped, rear is bi-amped, has 3 sets of inputs.
            To use wide band EQ you would need either 3 EQs', or a different EQ.
            If you go to DQXS, you get basically 3 of your EQ, PLUS all of the features of a 6XS...http://mobileaudiocontrol.com/produc...7&l1=5247&l2=#
            Then you could add a DDC http://mobileaudiocontrol.com/produc...47&l1=5247&l2=
            Then you could completely fuck up the sound quality of your bass by adding a second subwoofer, and worse still, make it ported!
            Luke
            Closing SOON!
            • kylebes1
              • May 2004
              • 2804
              Ok, forget the second sub then
              My headunit has six preamp outputs. Stereo Front, Rear and sub.
              I have two mids up front and two tweeters up front and the same setup for the rear.
              Thanks Luke, I wish I were closer so you could help me in person. I like doing stuff on my own, and with enough reading of owner's manuals I am figureing it all out.
