electronics messed up now...
  • Jahman093
    • Sep 2012
    • 183
    year/model 86 325
    just replaced my ignition switch and now my windows wont go down and when i first drove my car the tach worked and now ~2 hrs later it doesn't.
    any help to as what could cause this would be much appreciated.
    thanks!
  • oliver.r
    • Mar 2012
    • 3839
    That dosnt make any sense.
    For the windows check that the braker is pressed and the red isn't showing.
    If your mirrors work then that's probably your problem.
    If your mirrors also don't work it might be a fuse
    • AndrewBird
      The Mad Scientist
      • 11897
      My guess is it is unrelated to the ignition switch wiring, but was caused by you playing around under the dash. I would start by taking a look and seeing if there is anything obviously not right, like spliced wires or possibly an aftermarket alarm.
      • Jahman093
        • Sep 2012
        • 183
        okay got the window situation figured out. didnt have the breaker plugged in.
        now onto the tachometer. Is there anything that could cause it to stop working
        thanks again for the help!
        • Gregs///M
          • Mar 2012
          • 2459
          The MPG gauge and tach share the same signal. So if one works, while the other does not, the problem is in the cluster.
          The signal comes directly from the ECM and I don't think there are any connectors in that wire, it runs directly to the cluster. Black wire, blue connector.
          Most likely your SI board batteries just died unless you have replaced them before.
          Owner - Bavarian Restoration
          BMW and European Electronics Repair and Restoration
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
          Follow our Instagram!
