Help with Viper Alarm install please. Check my wiring
  • bmbarnum
    • Aug 2012
    • 55
    Hello everyone,
    I am attempting to install a Viper 5901 alarm system into my 1990 bmw 325i e30; however, the wiring looks a bit more complicated compared to the research I have done through forums here on R3v and e30tech where other members have installed their own alarm system and posted their wiring install process. Now, this is my first attempt at an alarm system and I do not wish to have it installed by a professional because I do feel confident in myself that I can install it myself with the help of the community here. Also, I definitely would love to learn.
    Below, I have provided the wire harness of the alarm and it's function and where I believe it connects to in the car behind the drivers kick panel. I will be installing my alarm behind my cluster and zip tied to the orange box which is the SRS module I believe?
    I think the reason I feel intimidated by the install is because all of the wires, but I am sure nearly half of it is even needed. I can be wrong though.
    I am looking to have the following functional:
    - keyless remote unlock/lock door entry
    - remote unlock/lock pop open trunk (i believe i'll need an actuator for this)
    - Remote start (Car is currently automatic; however, I will be converting it to 5 speed next weekend which is when I will be installing this alarm as well during that process.)
    I would really appreciate any kind of help to guide me into completing the installment. I hope this thread also helps those looking to learn how to install alarms into their e30 that looks as intimidating as mines with all these wires.
    ("??" indicates "Where the heck does this go?!")
    VIPER Primary H1, 12-pin harness
    --> CAR WIRE
    1. RED/WHITE (-) 200mA trunk release output --> DO NOT USE
    2. RED (+)12v constant input --> RED +12v constant
    3. BROWN (+)siren output --> Siren wire that will be placed under the hood
    4. WHITE/BROWN light flash isolation wire - PIN 87a of onboard relay --> ??
    5. BLACK (-) chassis ground --> BROWN ground wire
    6. VIOLET (+) door trigger input --> DO NOT USE
    7. BLUE (-) trunk pin / instant trigger input --> ??
    8. GREEN (-) door trigger input --> ??
    9. BLACK/WHITE (-)200mA dome light output --> BROWN/PURPLE
    10. WHITE/BLUE (-) remote start / turbo timer --> DO NOT USE
    11. WHITE parking light output --> GRAY/WHITE and GRAY/YELLOW (drivers and passenger light wires)
    12. ORANGE (-)500mA ground when armed --> DO NOT USE
    Viper Door lock harness, 3-pin connector --> Car Wire
    1. BLUE (+)lock (-)unlock output -->GREEN/BLUE
    2. EMPTY
    3. GREEN (-)lock (+)unlock output --> YELLOW/BLUE
    Viper remote start harness, 10-pin connector --> Car Wire
    1. PINK(+) ignition 1 input/output --> ??
    2. RED/WHITE(+) fused (30a) ignition 2 / flex relay input 87 --> ??
    3.ORANGE(+) accessory output --> PURPLE
    4. VIOLET(+) starter output (car side of starter kill) --> ??
    5. GREEN(+) starter input (key side of starter kill) --> ??
    6.RED(+) fused (30a) ignition 1 input --> ??
    7.PINK/WHITE(+) Ignition 2/ flex relay output --> ??
    8. PINK/BLACK(+) flex relay input 87a keyside (if required) of Flex relay --> ??
    9. RED/BLACK(+) fused (30a) accessory/starter input --> ??
    10. NC --> No Connection DO NOT USE
    Viper remote start input, 5-pin connector --> Car wire
    1. BLACK/WHITE (-)neutral safety switch input --> ??
    2. VIOLET/WHITE TACHOMETER INPUT WIRE --> ??
    3. BROWN (+) brake shutdown input wire
    --> ??4. GRAY N/O or N/C (-) HOOD pin switch input
    --> ??5. BLUE/WHITE (-) 200mA 2nd status/rear defogger output
    Viper auxiliary harness, 8-pin connector (I DONT THINK I NEED TO USE THIS HARNESS)
    1. LIGHT GREEN/BLACK (-) 200mA factory alarm disarm output
    2. LIGHT GREEN/WHITE (-)200mA factory alarm arm output
    3. WHITE/VIOLET (-)200mA AUX 1 output
    4. VIOLET/BLACK (-)200mA AUX 2 output
    5. WHITE/BLACK (-)200mA AUX 3 output
    6. LIGHT BLUE (-)200mA 2nd unlock output
    7. GRAY/BLACK (-)diesel wait to start input
    8. BROWN/BLACK (-)200mA horn honk output
    Viper remote start auxiliary output, 5-pin (I DONT THINK I NEED TO USE THIS HARNESS)
    1. PINK/WHITE (-)200mA flex relay control output
    2. ORANGE (-)200mA accessory output
    3. VIOLET (-)200mA starter output
    4. PINK (-)200mA ignition 1 output
    5. BLUE (-)200mA status output
  • Gregs///M
    • Mar 2012
    • 2459
    Lots of question marks here. I bet you could have answered most of these by reading the installation manual from DEI, which is fantastic. But here are my suggestions...
    1. RED/WHITE (-) 200mA trunk release output --> Your new trunk solenoid should have fused power according to install manual recommendations. This output drives the negative wire of the trunk solenoid so it opens up. 200ma should be enough, if not, you will need to use a relay.
    4. WHITE/BROWN light flash isolation wire - PIN 87a of onboard relay --> If your parking lights do not work, try sending 12 volts to this wire. It might not be needed. Check manual diagram for this.
    7. BLUE (-) trunk pin / instant trigger input --> instant trigger for alarm, connect to trunk light. This will make alarm trip when someone pry's the trunk open.
    8. GREEN (-) door trigger input --> Connect to door pin switch. Double check both the passenger and drivers door trigger this wire. If not connected, someone can open your doors without alarm triggering.
    1. PINK(+) ignition 1 input/output --> Connect the ignition source.
    4. VIOLET(+) starter output (car side of starter kill) --> Cut starter cable in half at ignition switch. This side connects to starter side.
    5. GREEN(+) starter input (key side of starter kill) --> This is the other side of starter cables you cut, to tell if this is the right side, try to start the car with the wire cut. The key side will show 12 volts during cranking, the starter side will not show any voltage because its cut.
    6.RED(+) fused (30a) ignition 1 input --> connect to ignition source.
    7.PINK/WHITE(+) Ignition 2/ flex relay output --> not needed.
    8. PINK/BLACK(+) flex relay input 87a keyside (if required) of Flex relay --> dont think you need this, double check manual. You might need it.
    9. RED/BLACK(+) fused (30a) accessory/starter input --> connect to accessory source at ignition switch.
    1. BLACK/WHITE (-)neutral safety switch input --> This wire must have a ground connection to enable remote starter. Use a toggle switch with other side connected to ground to enable/disable remote start. Or connect to Ebrake if ebrake uses negative trigger. If it uses positive trigger, use relay to reverse polarity.
    2. VIOLET/WHITE TACHOMETER INPUT WIRE --> You need tach input so the remote start knows the car is running. it can be found at diagnostic connector, cluster, or ECM. The color is solid black. Its in the blue connector behind cluster, easier to grab it there.
    3. BROWN (+) brake shutdown input wire. Connect to wire that shows 12 volts when brake pedal is pressed, should be easy to find.
    4. GRAY N/O or N/C (-) HOOD pin switch input. Connect to a hood pin switch or install one. This triggers alarm is someone prys your hood open.
    Good luck.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • Gruelius
      • Oct 2009
      • 298
      Is there a nice point to grab the switched ground for the doors from? or do you need to take it from the relay point? i remember when looking at the ETM it was going to be a pain to grab both door switches
      RIP 84 323i coupe 5spd w/ 14psi
      89' 318i
