One of the things (among many) that drives me nuts about my car is my speedo is way off due to varius factors, mostly wrong tire size. I was trying to figure out how to correct this, read some threads about tweaking the cluster, etc.
Then I came across this:
http://www.jegs.com/i/JEGS+Performan...FeN_QgodLSoAjw
Its basically a GPS based speed sender. It specifies that it works with "All speedos that accept 4000, 8000, or 16000 pulses per mile". No clue if that is what our car sends.
In my head (which is often not a good place for ideas to live) I'm thinking I could replace the speed sensor in the diff with this and get an accurate speed reading regardless of tire size.
Crazy or brilliant? (i do know gps speed readings may be a little laggy).
Edit: This one is more expensive but seems to be not limited to any specific pulses: http://www.autometer.com/cat_accesso...l.aspx?vid=234
