Anyone ever try to retrofit a BMW homelink mirror to E30? I know they have mulit functions (dimming, homelink, compress...etc) but all I want is the homelink function, anyone? :)
BMW Homelink/Compress/Alarm Mirror Retrofit?
Also i have a convertible so it goes right on the stock location on the windshield.
EDIT:
There are a few versions of that mirror. i believe there is one that has the homelink but no compass and maybe no dimming either but that i'm not sure of. -
I have it in my car. i got power from the check panel so it turns off when you pull the key from ignition. dimming, compass and homelink are fully automatic, doesn't need anything but power. you can hook up the reverse signal and then it won't dim if you're backing up so you can see but it's not really needed. i personally love it! it appears to be hard to program the homelink sometimes but it might be just me.
EDIT:
There are a few versions of that mirror. i believe there is one that has the homelink but no compass and maybe no dimming either but that i'm not sure of.92 Alpine White 325iC M-Tech II Appearance PackageComment
I guess you don't have a mirror yet. Here's an advice. These mirrors are expensive so to save some $$ I went on ebay and bought a mirror that have homelink, compass and all the bells and whistles BUT the mirror was broken so I got it for like $20. Then I searched again and bought another one that had nothing but dimming $25. I pulled the mirror out of that one and replaced the broken one. I had to cut the little window for the compass but it wasn't too hard and came out nice. The whole thing cost me $45 and I have a mirror that goes for over $200. You might be able to do something similar.
EDIT:
I just noticed you are in LA as well. Where exactly?Comment
Thanks, but do you need some kind of plug on the mirror, I think I need a adaptor...92 Alpine White 325iC M-Tech II Appearance PackageComment
Well I had a getto solution first. I took apart a totally different connector that was used roughly the dame sized pins and just pushed them on the 2 pins. Later I got 2 female connectors from a junkyard. I still have the getto solution installed and you can kinda see it in the picture.Comment
Well I had a getto solution first. I took apart a totally different connector that was used roughly the dame sized pins and just pushed them on the 2 pins. Later I got 2 female connectors from a junkyard. I still have the getto solution installed and you can kinda see it in the picture.92 Alpine White 325iC M-Tech II Appearance PackageComment
Humm...I try and it doesn't fit on mine...let me try again, BTW, how do you know what pin number is on the mirror?92 Alpine White 325iC M-Tech II Appearance PackageComment
If your mirror still doesn't fit, take a picture of your mount and the mirror so i can compare it to mine. Maybe something is fishy.Comment
Thanks, I will take some pictures tonight, so for a basic homelink function to work, just connect power (12V) on pin 3 and ground on pin 10 should work? Do I need to connect "other" wires?92 Alpine White 325iC M-Tech II Appearance PackageComment
For basic funcionality only power needed.Comment
