So I have never had a working speedometer, it has always jumped around. I have changed out clusters, speedometeres and circuit boards that have been refurbished. Gregs///m was nice enough to take my whole cluster and run tests and he found it to work perfectly with no hiccups. My thought now is that it has to be the pulse generator in the dif. I pulled it out and it was clean as a button but I did notice the wiring was a little ghetto.
My speedo jumps around until it is warm and then works as it should as long as I am going a constant speed. Works best on the freeway after being sufficiently warmed up.
The pics were taken after I removed the screws.
I am assuming this isn't stock, could this be the issue? I easily pulled them out with very little resistance.
Should I grab a plug from the yard and splice it in?
