Tach worked, now it doesn't, then it worked... now it doesn't again!
  • SkorcherX
    • Jun 2011
    • 267
    I did the swap (M50NV), and EVERYTHING worked. I installed an aftermarket stereo along with swapping the dash... Now the Tach does not work.
    I recently ran the car into a curb. After installing new control arms, bushings, sway bar bushings and tie-rod ends... the tach started working again, however the odometer stopped working.
    I took the cluster out to investigate the odometer (broken gear teeth) to find that when I re-installed the cluster, the tach would not work again.
    Here is the behavior of the needle which I found strange.
  • Prost
    • Nov 2012
    • 193
    http://www.youtube.com/watch?v=ZP5yV2vSR9w
    You have a E46 key, how'd you do that? Alarm with the key fob too?
    Sorry didn't know the answer of your questions
    92 Alpine White 325iC M-Tech II Appearance Package
    • Gregs///M
      • Mar 2012
      • 2459
      Most likely dead SI board batteries if they have not been changed before. SI board directly powers and controls tach, temp, and MPG gauge. Most often affects tach first.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • mentaleeill
        • 850
        check the tracer on the board. i have seen them burn, easily repaired with a piece of wire and some solder.
        • SkorcherX
          • Jun 2011
          • 267
          I spend the $30 and put new SI batteries in it. Didn't make a difference.
          This burned "trace". Could someone point me in the direction of a pic that would illustrate such a thing?
          • ///M42 sport
            • 3952
            you could send it into gregs///m to check?
            • mentaleeill
              • 850
              take the cluster apart, you'll see it it most likely. i dont have any pics or else i'd post it.
              • Gregs///M
                • Mar 2012
                • 2459
                Read this http://www.r3vlimited.com/board/showthread.php?t=274422
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
