Two Ground Wire?
  • Prost
    • Nov 2012
    • 193
    Two Ground Wire?
    I got this picture from eBay, I want to connect my homelink mirror and use this light to get power, I know the red/green wire is +12V power, but there are two brown ground, which one should I use?
    92 Alpine White 325iC M-Tech II Appearance Package
  • Gregs///M
    • Mar 2012
    • 2459
    Either is fine. Ground in BMW's, all of them, is always solid brown.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • oldmann
      • 265
      Two grounds, either will do. 2nd would be for next piece needing a ground.
      • treff-7
        • Sep 2009
        • 345
        It does matter which one you use! One of them is a constant ground, the other one is only grounded when you open a door. Check which way you need to slide the switch for the light to be constantly on and the wire on that side is the constant ground.
        Edit: Also i believe only one of them is solid brown (the constant ground). The other one is brown-purple or something like that.
        • StereoInstaller1
          GAS
          • 22679
          This.
          Closing SOON!
          Thanks for 10 years of fun!
          • Prost
            • Nov 2012
            • 193
            Which one you connect to your homelink as ground? the constant one or the door only one?
            • Gregs///M
              • Mar 2012
              • 2459
              Good find, my mistake. The picture looked like they were common with each other but "dome light trigger"...of course.
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
              • treff-7
                • Sep 2009
                • 345
                The constant one. Otherwise it will only work when you have one of the doors open. The switched +12V from the check panel will determine whether it's on or not. That way it will be energized when you turn the key to ACC (the first click).
                This is a typical sign of knowing too much. ;)
                The next step will be when you agree and disagree with yourself at the same time for personal reasons...
                • Prost
                  • Nov 2012
                  • 193
                  Got it ;)
