Replacing E30 head unit with aftermarket and retain premium sound and amp
  • Mr.SWISS
    • Nov 2005
    • 1251
    Anybody have a wiring diagram for this application? I want to ugrade the E30 radio since its volume knob is all worn out and randomly blows your ears out on a bump....
    Thought about taking the CD33 out of the roadster and putting it in the E30 and upgading the raodster stereo but I really just want a good radio in both cars.
    Ideally though I mean IDEALLY, I want a single din with a 4' screen DVD/nav & BT in the roady and cd33 in E30.
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
  • bmwguy325is
    • May 2011
    • 1263
    Im going to venture a guess that a modern radios internal amp has more power than that of an old BMW amp set up. So you may be wasting your time.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • StereoInstaller1
      GAS
      • 22679
      Yeah, it is simple and works fine, use the amp bypass thread for wiring diagrams.
      I don't know what year/model your E30 is, but the colors will be the same: yellows and blues with a brown/black (most likely) as the amps input ground.
      If you get stuck, hit me up...it is simple.
      (pointless too, why would you put such a crappy radio as a C33 in your car, ever...YUK!)
      Luke
      Oh, BTW, if you want a new option for that roadster, check out the new Parrot Asteroid "Smart", the first "half depth" double DIN Navigation deck, it is a winner.
      Closing SOON!
      Thanks for 10 years of fun!
      • Mr.SWISS
        • Nov 2005
        • 1251
        Luke
        Noted Ill take a look.
        As to the CD33 it is a factory look and it WORKS and has a tape deck for easy MP3 connection. I think it would look right at home in the ol e30.
        Specs:
        1989 325is 5spd/24v swapped.
        Edit: That Parrot Asteroid "Smart" is a double DIN Im looking to stay single.
        :nice:
        • pfahls1
          • 111
          Specs:
          There is a "classic" version that is single DIN...
          1986 BMW 325es
          2006 BMW 325i
          2003 GMC Envoy
          • StereoInstaller1
            GAS
            • 22679
            it is a miserable POS, do not even consider it
            Closing SOON!
